crank sensor
Old Feb 19, 2020 | 07:21 PM
preacher putz's Avatar
preacher putz
Default crank sensor
Can any of you tell me where the crankshaft sensor is physically located on a 96 LT!. The motor designation is P and it has an automatic
transmission
tks :Putz
Old Feb 19, 2020 | 08:45 PM
grandspt's Avatar
grandspt
It's located on the timing cover, lower left side facing the front of the engine.
The sensor has a weatherpack connector and the sensor is held in place by one bolt that is hard to get to.
Old Feb 20, 2020 | 09:21 AM
MatthewMiller's Avatar
MatthewMiller
Right, it's a PITA to reach because the front crossmember is right underneath the sensor. But it can be reached without lifting the engine if you have patience and the right wrenches.
To crank sensor
