Valve covers for LT4
Old Feb 23, 2020 | 05:45 PM
grandspt's Avatar
grandspt
Default Valve covers for LT4
So I have installed a new Lloyd Elliot cam and Lunati valvetrain per Lloyds recommendation. Now my stock composite valve covers won't clear the Lunati Rollerrockers and polylocks.
What kind of valve covers have you guys used that will clear the polylocks?
Old Feb 23, 2020 | 08:48 PM
Kevova's Avatar
Kevova
Are the rockers hitting cover at full lift or are the center bolts interfering?
Old Feb 23, 2020 | 09:20 PM
grandspt's Avatar
grandspt
It looks like the center polylocks are hitting the top of the cover. Not by much but it is definitely preventing the valve cover from seating properly.
Old Feb 23, 2020 | 10:27 PM
LTxDave's Avatar
LTxDave
I clearanced my 95 LT1 valve covers for poly locks. I believe the LT1 composite covers are different where the drip rail is from the lt4 cover, but I imagine if I could clearance these that you could clearance the LT4 covers as well.
Old Feb 24, 2020 | 04:43 AM
grandspt's Avatar
grandspt
I was thinking of trying a Mr. Gasket cork/rubber style gasket to replace the OEM silicone type insert. The cork/rubber looks like it will raise the cover a bit. Maybe enough to clear the polylocks?
But I thought I would ask the forum first if anyone found valve covers that would bolt up and give the clearance necessary.
Old Feb 24, 2020 | 07:33 AM
LTxDave's Avatar
LTxDave
I don't think they make cork gaskets for the composite covers. There might be something out there, but I even had to modify the aftermarket aluminium replacements that I had on at one time.
Old Feb 24, 2020 | 08:58 AM
fredk's Avatar
fredk
I removed the valve cover tabs on my LT1 when i installed my RR.
Old Feb 24, 2020 | 09:56 AM
grandspt's Avatar
grandspt
Valve cover tabs? Do you have a picture of the tabs? I am not picturing what the tabs are.
Old Feb 24, 2020 | 11:15 AM
RichS's Avatar
RichS
Your LT4 valve covers don't have drip tabs. I added a second thicker rubber type perimeter bolt valve cover gasket to clear my shaft rockers. I used tack adhesive to hold it to the head. Put a dab of rtv in the holes where the bolts normally would go. I also added 2 small lock washers under the centerbolt studs so you don't over tighten the torx bolts.
Old Feb 25, 2020 | 06:49 AM
grandspt's Avatar
grandspt
Thank you, I am going to give it a try. It looks like a gasket of about 0.185" will clear everything. I found Mr. gasket #5867 which is 0.187" thick and will fit the perimeter of the heads.
It also fits around my valve cover but the cover has no way of retaining the gasket. I am going to use The Right Stuff on the valve cover, slap the gasket on it and let it dry overnight. Then I will install it dry on the head portion. Hopefully the bolts are long enough to overcome the added 0.187".
Old Feb 25, 2020 | 07:14 AM
BlowerWorks's Avatar
BlowerWorks
Supporting Vendor
Back in the day we made aluminum spacers to lift the cover. Maybe somebody is making same today ?
Old Feb 25, 2020 | 11:38 AM
barchetta1's Avatar
barchetta1
Get "Mr. Gasket" gaskets.. they are 3x times as tall as stock valve cover gaskets in my opinion. They are cork with a rubber film on each side. You could even do two gaskets.
Old Feb 25, 2020 | 02:08 PM
fake's Avatar
fake
Cork is not the route to use Mobil ! will pass right through the cork. Just a heads up!
Old Feb 25, 2020 | 02:18 PM
barchetta1's Avatar
barchetta1
Mr. Gasket is a rubberized cork for the LT1.
Kevova's Avatar
Kevova
Since composite covers use "spaghetti" seal there isn't anything to get cork gasket from moving. Spacer is a available, but not with roller rockers. Another area of concern is alternator bracket interference. Canton make a tall cover set.
Old Feb 25, 2020 | 02:27 PM
barchetta1's Avatar
barchetta1
If you meant there is nothing to stop a cork gasket from moving I was concerned with this too and called Mr. Gasket (Holley) before I purchased. They assured me the gasket complies to the grooves in the composite cover. I have not had an issue with movement thus far. To be transparent Ive only had them on a few months so maybe I made a mistake only time will tell.
I like a stock looking engine even though the canton solution looks damn cool.. But I guess once your do roller rockers you arent stock anymore so Id likely go with the cantons that have the depression on the drivers side for the alternator. they reallysqueezed the alternator in there.. or I THINK you can buy a thinner alternator.. things just keep getting more and more expensive once you start messing with the recipe that is the LT1. If it were me Id see if a gasket would give me the clearance and then spend the big bucks if I had too. You can find slighly damaged cantons on ebay from time to time but even those arent super cheap.
FYI my eyeball of the Mr. gasket gasket says 1/4". Not sure how tall stock is because mine were factory and squashed pretty good and leaking badly.
Old Feb 25, 2020 | 07:51 PM
grandspt's Avatar
grandspt
I went with the Mr. Gasket cork/rubber gasket and The Right Stuff on my composite valve covers to keep them in place. No sealant used on the heads.
Hopefully this will hold up. We shall see.
I don't like the looks of the Cantons to be honest. A lot of the reviews on Summit Racing are poor for the Canton valve covers.
The breather and oil fill are on the wrong side. I also saw that people were unhappy with fitment, hitting the wiper motor, AC box and I even read that although they have a relief for the alternator it still hits it. All for $265.00!
Honestly it's hard to believe there are not many choices for aftermarket valve covers.
It looks like the stock composite covers like I have are being used by Camaro and Impala SS owners who have modified their LTx.
To Valve covers for LT4
Old Feb 25, 2020 | 07:56 PM
barchetta1's Avatar
barchetta1
I hope they work for us both! I wonder if there isnt an off the shelf alternator that is smaller that could be substituted. Then the market would be wide open for covers. I know Ive seen slimmer models but they were not cheap at all.. like $300+..
I take it by your post the gasket gave you the clearance you needed for your rockers?
Old Feb 25, 2020 | 08:17 PM
grandspt's Avatar
grandspt
Yes, the gasket 0.187" was what I needed to clear the polylocks. And now it still looks stock. Which is the look I am after.
The Proform valve covers come in black with a red Chevrolet logo embossed on it. To me it looks pretty nice. But it looks like it may hit the alternator.
Not sure about the Mobil One oil and cork/rubber gasket. I can't see how it would make much of a difference. I've used Mobil One on my old 1983 Z28 Camaro that I use to own and I beat the snot out of it. Several drag passes and hard street driving. Both the 305 HO and after a new ZZ3 350 crate motor. Both motors had cork gaskets and no leaks. Maybe I was just lucky.
Old Feb 25, 2020 | 08:22 PM
barchetta1's Avatar
barchetta1
Well, its not raw cork, its infused or whatever you want to call it with silicone. I do see that my gaskets are wet but that is what I was told would happen.. then the cork expands to further seal. I guess we will find out. I use high mileage mobil1 which is designed for older gaskets too if Im not mistaken. Sorry I guess I was way off when I said it looked like a 1/4" but glad its enough.
