trouble w/ exhaust leak
Old Nov 20, 2002 | 05:00 PM
jsaunde2's Avatar
jsaunde2
Default trouble w/ exhaust leak
I am having a hard time trying to get the left side of my exhaust to seal well with the cat. The top bolt is such a pain to get to that I think it is tight when it apparently is not. Everything works well for a while, then 1-2 weeks after working on it the leak returns. I am fairly sure this is the location of the leak as it goes away for a while after I R&R the exhaust.
Any pointers on how to maintain a good seal here?
Jason
Old Nov 20, 2002 | 05:05 PM
VBP's Avatar
VBP
St. Jude Donor '07,'13
Default Re: trouble w/ exhaust leak (jsaunde2)
You may want to check the catalytic converter. I'd be willing to bet it's plugged and building up pressure. :yesnod:
Old Nov 21, 2002 | 12:14 PM
jsaunde2's Avatar
jsaunde2
Default Re: trouble w/ exhaust leak (VBP)
I believe the leak is after the cat as that is what I am R&R. Also, I had new cats put on about 18 months ago, so if they are clogged then I have some serious problem.
Jason
Old Nov 21, 2002 | 01:07 PM
VBP's Avatar
VBP
Check the motor and tranny mounts to see if the motor is torqueing up which will tweak the exhaust. I've seen them loosen up that way too. :yesnod:
To trouble w/ exhaust leak
