Hi,
When I apply 12V from the battery to port "G" in the ALDL, I can hear my pump runs as long there is 12V to G and getting about 30psi.
I normal condition, the pressure should stay when I disconnect the 12V to G? In my case it drops to zero. There is no fuel in the hose of the FPR. No, fuel when I press the schrader valve.
Yes,I have fuel in the tank.
If it's not the FPR, then the gas has to either be leaking into a cylinder from an injector, or running back into the tank because of the fuel pump... There is no where else for it to go and not be seen on the ground. If I'm not mistaken you should be able to turn on the key to energize the pump, then pinch off the supply line, then turn off the key... If the system holds pressure with the line pinched off , then loses pressure when unpinched ,then it's most likely the pump is bad... WW
Hi.
I opened the fuel tank cap and made a voice record with the cell phone. I can heard the pump working while G got 12v. I couldn’t hear other thing besides the pump itself. I already ordered a new fuel pump. The one I have was bought from racetronix about 10k miles ago. Walbro 160/180 lph as far as I remember. My next step is to replace it with the new one.
We use 95RON gasoline. I assume its 91/93 in the States.
Usually a pump does not fail in a way that cause it to loose pressure/flow. If they do it is usually because of a clogged filter sock or a leak in the fuel tank ( bad hose).
I would check that hose and add hose clamps and check the filter sock.
When the pump is out you can test it on the bench, both flow and pressure.
