TunerCAT
Old Nov 20, 2002 | 08:30 PM
tommelton's Avatar
tommelton
Default TunerCAT
Ok, it appears I am going to get into programming for my car. It is a 1986 with the factory ECM, 1277165. I *think* I want TunerCAT. Is it easiest to use? I downloaded WinBin, but the screenshots from TunerCAT look so much better! Also, if I go with TunerCAT, I think I want two different ECM definition files, one for the 86 specific $32, and also the 89 specific $6E.
Does this make sense? The following are my current mods:
ZZ4
ZF6 6 speed conversion
3.45 Dana 44
SuperRam plenum and base
1.6 roller rockers
AFPR
TPIS headers
Random Tech cat
Borla rear y-pipe
Dynomax ultra-flow mufflers
53mm TB (about to install)
Thoughts??? Thanks for any guidance.
Tom Melton
82 CE
86 Z51 coupe
[Modified by tommelton, 8:31 PM 11/20/2002]
Old Nov 20, 2002 | 10:44 PM
18carfan's Avatar
18carfan
Cruise-In II Veteran
Default Re: TunerCAT (tommelton)
Tom,
Tunercat is a good program and the support from them is good too. I would recommend it. Getting both the definition files is probably a good idea although I've never looked back since going to the 6E code. I just like the driveability so much more. To be honest though, I haven't messed with MAF tuning for quite some time. The speed-density systems are just so easier for me for some reason. I've yet to convert my car though just been "playing" with everyone elses projects. -Jeff
BTW - What are you using for datalogging?
Old Nov 20, 2002 | 11:18 PM
tommelton's Avatar
tommelton
Default Re: TunerCAT (18carfan)
Hi Jeff. I have Diacom+ for logging. Thanks for the response.
Any news on the brake pad clips?
-Tom
Old Nov 22, 2002 | 11:06 AM
18carfan's Avatar
18carfan
You really need to consider Datamaster or Ease. They are much better IMO.
Shipped Wednesday.
To TunerCAT
