3 wire O2 question
Old Nov 20, 2002 | 10:52 PM
Nathan Plemons's Avatar
Nathan Plemons
Default 3 wire O2 question
I just recieved my 3 wire heated O2 sensors from Jeff Kopp. Outstanding considering that I ordered them on Monday! Anyway, I'm looking at them and I see 3 wires of course. Two are brown, one is purple. I assume the purple is the signal wire. That leaves the two brown wires. For all I can tell they are the same. Does it matter which way I hook these up? One of them needs to be 12 volts the other needs to be a ground but does it matter which one?
I'm thinking that it shouldn't matter. If it's just a resistive type heater it really shouldn't matter which way the current flows through it should it?
Old Nov 20, 2002 | 11:21 PM
trupp's Avatar
trupp
Default Re: 3 wire O2 question (Nathan Plemons)
You are correct the two brown wires are for the heater. And they are non polar. Hook them up either way.
Old Nov 21, 2002 | 09:52 AM
NavyVet's Avatar
NavyVet
Default More on 3-wire heated O2 sensors
Those that have done this - did you use a relay for the heated wires, or did you wire one straight to 12V source? Thanks in advance.
[Modified by NavyVet, 9:02 AM 11/21/2002]
Old Nov 21, 2002 | 11:59 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: More on 3-wire heated O2 sensors (NavyVet)
Doesn't matter the polarity. I just ran mine to an ignition controlled 12v source. Wiper motor works nicely. I am planning on putting a fuse panel out under the hood for all the goodies.. :cheers:
Old Nov 21, 2002 | 02:04 PM
No Ordinary 91's Avatar
No Ordinary 91
Cruise-In III Veteran
Default Re: More on 3-wire heated O2 sensors (ski_dwn_it)
Thats what I did as well, no relay, but I used GM connectors so there is no "spliced" wires, and I can pull the 3 wire out and replace it with a single wire in a snap just incase something happens
To 3 wire O2 question
