Code ECM
Old Mar 15, 2020 | 02:42 PM
jerem.13_fma's Avatar
jerem.13_fma
3rd Gear
Default Code ECM
Hi,
I need help for my vette 92 lt1, the engine can't start.
she was fail to the road at 50km/h, i was able to tow and went to my home.
I sent ECM and CCM in rebuilding but no way; she refuse starting
I have reader code for vette 92 OBD1 and he read thi data codes:
-BLM right : 128
-CCP Solenoid : OFF
-EGR Diag : open
-EGR duty : 0%
-ESC counter : 0
-IAC position : 160
-IDLE REQ RPM: 3188
-Knock RET: 0
-Loop Status : open
-MAP HG: 30.08
-MAP V: 4,86v
-MAP F°: 212
-Port throttle req: NO
-Port THROST : CLSD
-Port vac V: 4,84v
Prom ID : 3881
-TPS sensor : 0.66
-1ST GEAR SW: ON
-4th GEAR SW : OFF
-Code present: NO
Somebody have idea? The problem could be SW GEAR no? Even in Neutral or Parc, Sw Gear 1 was on
Thank you
Jeremy
France
Old Mar 16, 2020 | 12:36 PM
Kevova's Avatar
Kevova
You need to go through the basics first. Fuel pressure over 293 kpa. Injector pulse - noid or injector test light. Check multiple injectors for blink while cranking. Ecm turns on 4 injectors at a time. Spark at atleast 2 plug wires while cranking. You need to invest in factory service manuals paper, disc, or online. Ideally the French version used in Quebec Canada.
Old Mar 16, 2020 | 04:06 PM
Mrvettenick's Avatar
Mrvettenick
If there are no codes, then you must make sure that you have fuel pressure and spark. Does the fuel pump even run for 2 seconds when the key is turned to the on position?
Does it even crank? This is just the beginning of basics. If you can be a little more descriptive, we can help/
Old Mar 22, 2020 | 11:45 AM
jerem.13_fma
3rd Gear
Hi and thank you for your help,
When the key turn ON:
-Fuel pump turn on, but the starter can't start; He haven't the order ignition.
-The interior light turn On, and the central control light up "service engine soon" and "asr OFF"
-The Stanger think is the light road order can't work but the turn light is right.
-The LCD centrale doesn't light up but "door ajar" and other light is ok.
I think problem is ground electrical but where ...; behind CCM ? or in the Module ASR ? ..
To Code ECM
