C5 wheels on a C4
Old Mar 18, 2020 | 05:23 PM
GSPORT96's Avatar
GSPORT96
Default C5 wheels on a C4
Anyone know if 2000 C5 wheels will fit on a 1989 C4 ? Any fitment requirements. C5 Wheels and tires are stock size. Thanks
Old Mar 18, 2020 | 10:08 PM
NASCAR314's Avatar
NASCAR314
I know they fit a 96, and I think 88 thru 96 are all the same, this pic has C5 rears (18" x 9.5") on front and C5 Z06 (18" x 10.5") on the rear and fit with no problems, stock suspension.
Old Mar 19, 2020 | 08:18 AM
vettehardt's Avatar
vettehardt
Yes you can use the C5 wheels with no issues. The front 17" wheels may sit inboard a bit. If you want them more flush with the fenders, you may need to run a spacer/adapter. I run the 18x9.5 at all four corners while autocrossing and there are no issues.
Old Mar 19, 2020 | 08:10 PM
GSPORT96's Avatar
GSPORT96
What size spacers do you think are correct? one inch? Or less? Many Thanks
Old Mar 19, 2020 | 08:12 PM
GSPORT96's Avatar
GSPORT96
The rims I have are the five spoke rims, same as on the C5 LeMans Blue Commemorative Edition. Not like the early C5 wheels that are flat.. Thanks Again
Old Mar 19, 2020 | 10:01 PM
NASCAR314's Avatar
NASCAR314
The C5 commemorative are the same backspacing as what you call "flat", yes, they will fit. As for spacers, a 1/2" is fine. If you look at my pic above you can see I have longer wheels studs installed so I can run 1/2" spacers if I wish. The spacers are NOT installed in the pic above. I DO run those spacers on the front IF I have 18" x 10.5" Z06 wheels on the front running 315 tires to prevent minor tire rub at full lock steering on the plastic inner fenders at maximum negative camber.
I also have a 2004 C5 Z06 Commemorative Edition Z16 and have run those wheels on my 1996 with no issues, used them as rain tires in autocrossing.
Your good to go, 17" or 18" without spacers. If you want spacers, 1/2" is plenty, but you need longer studs, so you gotta take off the bearing / hub assembly and press out the stock and install new
ARP 1007708 Wheel Studs at $26.30 for 5 pack at Amazon
Old Mar 20, 2020 | 06:14 PM
GSPORT96's Avatar
GSPORT96
Thank you so much for your input. Happy racing.
Old Mar 21, 2020 | 08:29 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Default C5Z wheels on early C4?
Now that the OP's question has been answered, I hope he won't mind if I ask a similar type question. Anyone run a set of C5Z 18/17 inch wheels on an early (narrower) C4?
Thanks for any input.
Old Mar 21, 2020 | 10:59 PM
jv9999's Avatar
jv9999
What's earlier? I run C5 wheels on my '90 with 3/4" spacers in the front and 1" in the back. It gets a lot of compliments.
Old Mar 21, 2020 | 11:38 PM
MatthewMiller's Avatar
MatthewMiller
He means 84-87, which require less offset because their hub faces are about 18mm inboard compared to later C4s that have "zero-scrub radius" geometry. You can certainly run those wheels on an early C4, but you'll want to use spacers to push them outward a bit (i.e., subtract some of their offset). In back, I believe 3/4" spacers would be correct, and probably up front too.
To C5 wheels on a C4
