Air pump motor
Old Mar 22, 2020 | 05:40 AM
Haggisbash's Avatar
Haggisbash
Default Air pump motor
How much noise should I expect to hear when this pump motor is running? I think its quite noticeable, I can easily hear it when first starting the car if I'm standing beside it.
Old Mar 22, 2020 | 05:57 AM
eutu1984's Avatar
eutu1984
2021 C4 of the Year - Modified Finalist
What type of noises are you hearing. If you think it's a bearing noise disconnect the belt and check for play in the pulley, also check the idler pulley.
Old Mar 22, 2020 | 02:03 PM
Haggisbash's Avatar
Haggisbash
I should have mentioned that this is a '93 and the air pump is self powered. To me is sounds like the bearings are worn but I don't have another car nearby that I can listen to. The other regulars who turn up for our runs are driving earlier C4 versions.
Old Mar 22, 2020 | 02:35 PM
eutu1984's Avatar
eutu1984
if it's an electric one I would not worry to much if it does give up the ghost it will not harm anything it just pumps air into your exhaust during the first few moments of running to lower your emissions.
To Air pump motor
