Any advice on changing the left side plugs. The passenger side was kinda ez. The dr side plugs are waaaay in there with a lot of stuff around them.
thanks Thad
There is no easy way to do them. May want to try going from the bottom of the car. I have headers on mine and some are accessed from the top and some are accessed from the bottom, all are a PITA.
What you need.
1. Spark Plug Socket
2. Pass through Socket
3. 3 different extension lenghts
4. U-join extension
5. ratchet
6. Combination wrench that fits both sockets
7. Jack
8. Jack Stands
9. Few Bottles of your favorite brew
10. About 6 hours of time if it's your first time.
Some you will get from the top, others from the bottom. I made a list per cylinder of what combination I used to get each one. Unfortunately,it is in my notes at home. It can just be a bit of a frustrating job is all.
