Clutch Question
Old Mar 24, 2020 | 07:56 PM
GaryInArizona's Avatar
GaryInArizona
Default Clutch Question
Changing from DMF to single will I need to re balance my new single flywheel to match old DMF?
Old Mar 24, 2020 | 08:09 PM
Kevova's Avatar
Kevova
Lt1 There's a little to it.Fidenza has aluminum with replaceable iron insert. Flywheel will need balance weight. It maybe a separate peice that bolts between crank and flywheel.
Old Mar 24, 2020 | 08:23 PM
dizwiz24's Avatar
dizwiz24
My lightweight fidanza flywheel has a little weight that bolts to the backside of it.
i took the weight off, neutral balanced the new SPEC pressure plate to the alum flywheel.
Then I put the weight back on, and clocked it exactly where the extra mass was on the dual mass flywheel
I had a machine shop check all this.
dont want to put it back together and have a vibration.
just be sure to note the orientation the dual mass was when you remove it. Though there may be an offset there so you can only install it one way.
bottom line is that the extra weight on the single mass flywheel needs to be clocked to the crank exactly where the extra weight was on the dual mass flywheel
Old Mar 24, 2020 | 08:28 PM
GaryInArizona
Yes LT1. 94 ZF6 black tag. I already have a new flywheel. Nothing fancy just stock replacement. Just wondering if I have to get it re-balanced to match my old DFM?
Or can I just bolt it on? I've heard it may have a vibration after switching to single from DFM. What do you think?
Old Mar 24, 2020 | 08:53 PM
Kevova's Avatar
Kevova
If flywheel was LT1 specific it may have weight made to it. It's a question for supplier or possibly there is a note in paperwork.
There are several threads related to installing solid flywheel.
Old Mar 24, 2020 | 08:58 PM
GaryInArizona
Yes it is LT1 specific. I think I'm going to take everything to machine shop and have them look at it before I install it. Thanks for the info.
Old Apr 6, 2020 | 08:57 PM
DAVECAD2.0's Avatar
DAVECAD2.0
Gary:
Your in luck. Contact ZFdoc. He's lives in Arizona. Top guru on C4 clutches and ZF trannies.
Dave.
To Clutch Question
