383 build help guys!
Old Mar 25, 2020 | 04:55 AM
BronnyD's Avatar
BronnyD
6th Gear
Default 383 build help guys!
Hey guys,
I'm looking to start on a new project. I am wanting to build a stroker. I have did small rebuilds on sbc before but never built one with performance in mind. I was hoping you guys could give me some ideas on cam and head specs..pistons and such. I guess pretty much a build sheet Recommendation. At the moment I have a 350 4 bolt block in my garage. I do not have a budget in mind. I will be dropping it in my c4 as soon as I am done. I do have several machine shops locally to help with any work needed to be done. My prefered goals is to have it as my daily driver yet take it to the strip on the weekends. Pump gas is a must. I'm very much concerned about good quality parts. I do have a nex kit laying around I would be interested in hooking up. 400 to 450 would be quite fun I believe.
I appreciate any and all inside...Recommendations!!
Old Mar 25, 2020 | 05:18 AM
BronnyD's Avatar
BronnyD
6th Gear
I was thinking about comps hydraulic roller 270/276 .495/.502with 110 separation. Afr 195cc 64cc 2.02 intake 1.60 exhaust.
scat crank 9000 crank...Keith black pistons?? Eld intake with 670 or 750 holly mabe?
Old Mar 25, 2020 | 05:57 AM
drcook's Avatar
drcook
Finalist 2020 C4 of the Year - Modified
Unless you have bought a car since you joined
https://www.corvetteforum.com/forums...-got-here.html
Building an engine before you have acquired the platform is a bit of putting the cart before the horse. There are considerations regarding which year you are building for.
Old Mar 25, 2020 | 07:14 AM
BronnyD's Avatar
BronnyD
6th Gear
I said in my post I wanted to build a motor to drop in MY c4 as in I currently own one. The first thread was from several months ago...I did find a "93 here about a month ago. I enjoy driving it just would like to see a bit more power. As I have already done some brake..suspension..trans work
New battery..a/c...it has a solid frame and paint.
Old Mar 25, 2020 | 07:18 AM
BronnyD's Avatar
BronnyD
6th Gear
Btw what exactly do you mean there are considerations pertaining to the specific year??? I honestly haven't noticed alot pertaining to different years within 4th gen as far as engine compartment size...or weight for the most part.
Old Mar 25, 2020 | 09:31 AM
drcook's Avatar
drcook
Nowhere on the forum have you stated you bought a car, we are not mind readers. I looked.
93 is not a standard SBC. It is a LT1 engine, a gen 2 SBC. Now if you are going to bypass the computer and just go old school, then a std SBC will work. However, you will have the SES light to deal with being on. I don't know what effect that will have on the body control module, etc. Others will have to chime in,
Like I said,
it makes a difference.
Time to do some research.
Old Mar 25, 2020 | 09:58 AM
fredk's Avatar
fredk
He said he is going to drop it in his C4 so he must own one. Boy what nit picking !!!
Old Mar 25, 2020 | 10:17 AM
drcook's Avatar
drcook
Look at the time frame. Not much time since he introduced himself, and now, and only a total of 3 posts until this morning. NO WHERE DUDE did he say he got it and what it was. And if you know anything about C4's you know it does make a difference.
It also makes a difference where he lives as to what pollution controls need to be retained (if any). This was the last year of my 96 needing EPA checking, unlike California.
But you must be the great Carnac the Magnificent and was able to deduce that he bought it and what year it was, and where he lives.
Old Mar 25, 2020 | 10:43 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
OP should help us, help him.
I don't know how it's possible to go to a carb on a '93....and still have functional ABS/ASR etc. I agree that the BCM will have issues. I guess you could leave the ECM in place...it just wouldn't ever "know" that the engine is running?
Old Mar 25, 2020 | 10:50 AM
drcook's Avatar
drcook
Thank You
Old Mar 25, 2020 | 02:15 PM
BronnyD's Avatar
BronnyD
6th Gear
Haha dude I said in MY c4...I guess it's not so ecological for some people as I should have stated in the very beginning what color the carpet was for you..my bad. 🤭 Atleast Fred got it! I can done see this isn't the place to get help just either some dude in their 20s high testosterone at there daddy's garage or in there 90s pisses off because there took the wrong career path.
Old Mar 25, 2020 | 02:34 PM
htrdbmr's Avatar
htrdbmr
I was going to offer suggestions, but it looks it would be too much trouble. Good luck with it.
Old Mar 25, 2020 | 02:54 PM
vette196's Avatar
vette196
welcome! 6 posts in and you broad brush the whole group here. Remember the saying "you get more with honey than you do with vinegar"
Old Mar 25, 2020 | 04:30 PM
drcook's Avatar
drcook
It is obvious that there is no phuking clue here. No phuking clue about C4 Corvettes, no phuking clue about me, or Tom.
Have at it bud. Come back and tell us how it worked out for you. Try and marry a Generation 1 small block in with a Generation 2. Or rip out the LT1 and leave the ECM not connected and let us know how the dash does or doesn't work anymore. Or maybe try and put the OptiSpark on the front the the Gen 1 SBC.
You see it all matters. It matters what year C4. It matters which generation small block chevy engine. So simply saying you want to build a SBC for a C4, well have at it.
You come on here like a multitude of other trolls. A couple months ago you show up and you are going to get a C4, then the next post starts talking about building an engine without even telling folks what you bought and that you even bought without any consideration that a C4 is just not a C4.
Old Mar 25, 2020 | 07:46 PM
ghoastrider1's Avatar
ghoastrider1
your messing with the wrong folks by dishing TOM and DR, Cook, these two members KNOW their stuff,When they ask a question its for help in giving you the correct answer, Idle down some my friend and ease your wat in here, Many are friends, NOW, welcome to the site and lets start all over.
Old Mar 25, 2020 | 10:50 PM
Jaime-Corvette's Avatar
Jaime-Corvette
Heck if the op was me I would suck it up and accept to be put in my place in the sake to just get all the help I can. Weather or not I think I'm right or wrong I dont care... a nice restart would be acceptable??
Ps: trying to help here
Old Mar 26, 2020 | 12:52 AM
Hot Rod Roy's Avatar
Hot Rod Roy
p.s. fredk: Not all C4's are the same, and not all 350 SBC engines are the same. We need more info before we can speculate on any recommendations.
After the OP's tirade in post #11, I'm going to guess that he's gone. It's his loss! There are a lot of talented people here that could offer him some valuable help.
To 383 build help guys!
Old Mar 26, 2020 | 09:53 AM
fredk's Avatar
fredk
Well cook I guess your poop doesn't smell either. I read his post and he said to drop into his C4. What a dick you are !!!!
Old Mar 26, 2020 | 09:56 AM
vette196's Avatar
vette196
so because some newbie came on and over reacted. Two senior members are going at it. No name calling and step back. We're better than that on this forum
Old Mar 26, 2020 | 02:23 PM
drcook's Avatar
drcook
well fredk, you tell me from that post, L98 or LT1 well huh I am listening ....................... I am also listening for you to tell us how to put an unknown generation SBC into an unknown iteration C4 with a carberator and make it work, well huh I am listening .......................... Also after the his first post that said he was thinking about getting a C4 and then the very next post says he is wanting to build a SBC for a C4 that we didn't know he bought yet, so how do we know, well huh, I am listening.............
whether you want to admit it or not, that fits the pattern of a troll, just like he who won't be named.
so you tell me and the whole forum how you are going to fill in the gaps and tell him how to build a SBC, I am listening, here is the chance to show your expertise. to show how you can magically deduce through the internet, to automatically answer all the questions and build the most bestest build there is
his first 2 posts:
on 11/07/2019:
Hello,
New to the forum and wanted to introduce myself. From N.C...currently loving in Oregon. Not yet a vette owner but I am looking to buy a c4 here soon. I thought this place would be a great place for tons of information throughout the buying process and ownership. Thanks for having me.
Peace
then the next post is jumping into building the engine, no I bought one, I got a 1993, just a "going to build the engine and
he didn't notice there was a generation 1 and 2 SBC, do you know that oh great guru of the C4 forum ?
so as I said, you explain how to do it and then I will acknowledge your great guruness......
