Fu@#ing miss fire still
Old Mar 28, 2020 | 02:06 PM
Brandonvette's Avatar
Brandonvette
Default Fu@#ing miss fire still
I'm lost at what to try next . Had a miss before install of new mini ram an injectors and still have a miss at idle after the install. Parts that are new . Mini ram: injectors: IAC: tps : and yes are installed and volts are right and did the IAC set up by unplugging it and plugging back in the 1/4 throttle and start for five seconds and shut offvstart again ten seconds later. New fuel pump . Mass air flow sensor. Ingnition coil. Ingnition module. And now I just put new cap and rotor and plugs and wires and still have a miss at idle but goes away when reved up. The was only one plug I didn't change was number 6 I couldn't get it with the new headers but what's the odds that's the one that's bad? I did a old school check to see if I have a burnt valve I held a a peace of plastic bag over the tail pipes and it didn't try to suck it into the exsaust . I'm scared now I'm afraid I either got a cam lob starting to go flat or I have a valve that's bad. The new engine only got 450 miles on it . PLEASE HELP
Old Mar 28, 2020 | 02:27 PM
84 4+3's Avatar
84 4+3
Couple of suggestions below but first... what kind of plugs are you running? How did the old ones look. Even color on all of them?
Flat lobe is easy to spot... pull the valve cover and watch the rockers... they should all move evenly. That being said it would get worse as you drove it not go away... you also would hear it... and if you drained the oil right now you would also see it...
To see if the #6 is the culprit... take an IR probe to the exhaust ports and check temp across them. They should all be even.
So the order I would check? Answer the first couple things I asked in the first block. (Plug condition etc.) Then report back. Photos help.
next... Check temp with an IR probe or water... if one is weak it won't sizzle as fast if you squirt water on it.
Then pull the V/C and look at the rocker movement on the side that isn't up to snuff (if so)...thats all pretty much free.
Then if you are flattening a lobe pull the oil and get the cam out. You're only hurting things. However that is if the troubleshooting runs like that...
Old Mar 28, 2020 | 02:47 PM
Brandonvette
Ngk heat range 4
Old Mar 28, 2020 | 02:56 PM
Brandonvette
One I just pulled with five miles on it after plug install and running it hard them old ones I ran a little bit till i got my chip back from pcm of nc with the new burn for the mini ram
Old Mar 28, 2020 | 02:57 PM
84 4+3's Avatar
84 4+3
Definitely not what I'd call even... hmm... do the temperature test. Let it run for a bit warm up then either probe or squirt the water on each tube... then report back.
Was the miss occurring right away or did it take time to happen? Also, are you able to monitor afr?
Edit: that new plug looks alright.
Old Mar 28, 2020 | 03:05 PM
Brandonvette
the mis is very settle when cold but notice it but worsen when warm up hang tight I'm going to start it and spray the headers with water to see if I can see a diff
Old Mar 28, 2020 | 03:16 PM
Brandonvette
Ok so inlet it warm up sprayed the headers they all evaporated quick except number 2 cylinder the water will sit for a while till it evaporated so number two the problem but why now ?
Old Mar 28, 2020 | 03:31 PM
84 4+3's Avatar
84 4+3
You have a compression tester or do you want to pull the valve cover? If you have a tester just check compression on that cylinder then say #4 and see if there is a difference. Or pop the valve cover and see if the rockers move equally or if just by touching them they are loose.
Old Mar 28, 2020 | 03:38 PM
Brandonvette
Ill see if I can get a compression tester from someone tomorrow plus I might even pull the cover tomorrow an see what's up thanks ALOT I really appreciate the help and advice I'll keep ya posted on my findings hopefully tomorrow but what's your thoughts of now? Either a burnt valve or cam lobe ? Either way its bad
Old Mar 28, 2020 | 04:55 PM
84 4+3's Avatar
84 4+3
I'm hoping valves not adjusted right for you... but it is a flat tappet? Solid or hydraulic? Do you hear any valve noise? The other thing it could be is a valve sticking in the guide... I have had that happen and it'll behave similar. Cold not as bad because the richer idle masks it. It drove fine around too off idle.
Old Mar 28, 2020 | 05:06 PM
Brandonvette
​​​Hydraulic flat tappet
I do hear some noice on cold start bit goes away after 2 min of warming up
Old Mar 28, 2020 | 05:08 PM
84 4+3's Avatar
84 4+3
Hopefully its a valve adjustment then.
Old Mar 28, 2020 | 05:10 PM
Brandonvette
Im not that lucky
Old Mar 28, 2020 | 05:17 PM
84 4+3's Avatar
84 4+3
Im not that lucky
trust me... I am not that lucky. Most others would be.
Old Mar 29, 2020 | 11:54 AM
Brandonvette
Took the valve cover off and pulled the fuel pump fuse and had the wife crank while I watched. The number two cylinder exsaust valve moved equal to the rest. Just did a compression check on number 2 cylinder and got 130. Did another on the number 3 cause is the easiest to get to and got 160. Burnt valve ???
Old Mar 29, 2020 | 01:31 PM
84 4+3's Avatar
84 4+3
Can you hook your air compressor up to the compression tester fitting and see where the air is leaking from. Valve adjustment could still be off... 30 isn't horrible cold.
Old Mar 29, 2020 | 01:42 PM
Brandonvette
Un able to hook air up and I think the rockers are adjusted right there's no noice from the passenger side I hear it from the drivers drive and after two min it goes away . When I pulled the plug out number two it doesn't look like it's trying to turn brown like the one on the pic I showed you after a five min run
To Fu@#ing miss fire still
Old Mar 29, 2020 | 01:45 PM
Brandonvette
O of it means anything else too. I took the oil cap off while it's running and now it's blowing a little air out I don't remember it doin that before
Plus now you can hear puff sounds out the mufflerdont ever remember it idle like that
Old Mar 29, 2020 | 02:49 PM
84 4+3's Avatar
84 4+3
That... that almost sounds like a ring...
Old Mar 29, 2020 | 02:54 PM
Brandonvette
Would explain low compression then
