SR install
Old Nov 22, 2002 | 09:50 AM
GusBustamanteJr's Avatar
GusBustamanteJr
Default SR install
Okay, you SR guys, what did you do with the injector harness? I cant really find a good neat way to run it. It wont fit between the valvecover and manifold anymore. I think iunder the plenum just inside the runners might be it, but it doesnt look very good. What have you guys done?
Old Nov 22, 2002 | 10:01 AM
89vette's Avatar
89vette
Default Re: SR install (GusBustamanteJr)
It works. Just stuff it in down between the runners and valve cover. What I don't run down there is the PCV hoses. Cut the little plastic tabs off that would normally bolt to the manifold to make room.
Jason
Old Nov 22, 2002 | 10:40 AM
scorp508's Avatar
scorp508
Mine are between the valve covers and runners.
Old Nov 22, 2002 | 10:41 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: (scorp508)
Custom chip is being sent at noon today! :cheers:
[Modified by ski_dwn_it, 10:47 AM 11/22/2002]
Old Nov 22, 2002 | 11:31 AM
GusBustamanteJr
Scorp & Ski, did you fit them in there with the plastic sheath on? Im not using stock valve covers, maybe thats why it seems so tight.
Old Nov 22, 2002 | 11:33 AM
GusBustamanteJr
Default Re: (ski_dwn_it)
I was wondering about that chip......you said you shipped on Tuesday so I was looking all over my front porch and yard! Put the check box and sticker for Saturday delivery so I can have it for this weekend.
Thanks!!!
Old Nov 22, 2002 | 11:36 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: (GusBustamanteJr)
I was all planned to ship that day, then the baby sitter called me and my 1 yr old was running a 105 fever. Sorry I did not get back to you sooner. Now I feel like I am getting it. :rolleyes:
As for the wiring, Leave the plastic on and just shove it HARD! Its will slide in there. I have aftermarket covers too. Its tight!
[Modified by ski_dwn_it, 11:39 AM 11/22/2002]
Old Nov 22, 2002 | 11:38 AM
scorp508's Avatar
scorp508
.....did you fit them in there with the plastic sheath on?
Yep!
Old Nov 22, 2002 | 11:59 AM
GusBustamanteJr
Jesse, sorry to hear that, you really need to be careful with those fevers, my little ones had that bug that was going around, and my wife and I didnt sleep for a week. I have a 2 yr old and a 7 month old.....they are a full time job when they are sick!!! I feel for ya, take care of them first, of course. Do you have AIM or YIM?
Whats your Nick?
Old Nov 22, 2002 | 01:08 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Whats your Nick?
Thanks Gus...You chip has been sent via FedEx at noon today. The truck was just pulling it to pick up so you should have it tomorrow.
You will have to explain the above questions.
I got an IM from you, but the screen was all messed up since the change over. Email me please if you have questions.
Enjoy. :cheers:
Old Nov 22, 2002 | 01:11 PM
GusBustamanteJr
AOL Instant Messenger or Yahoo Instant Messenger, and your ID's on each!
Thanks!
Old Nov 22, 2002 | 01:58 PM
J Z06's Avatar
J Z06
Default SR install
To neaten things up a bit, We took off the plastic thingamajig and wrapped the harness with tape(ala ralph) and then snuck everything underneath the runners(also noticed that from ralphs engine) it looks much nicer. I have pictures, but that particular area doesn't show the detail.
Good luck with it.
Old Nov 22, 2002 | 03:04 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: SR install (JD 90 383)
I noticed that on Ralph engine too. It will also be one less thing in the way when I pull the valve covers. Will have to do that more with the solid cam :D Now if I could figure out a way to get that pesky AC pump to clear the valve cover on the pass side! What a PITA to get that bracket out of the way. :eek:
:cheers:
Old Nov 22, 2002 | 03:59 PM
J Z06's Avatar
J Z06
Default SR install
Yes
The a/c bracket is a mother. It looks nice though with everything UNDER the runners.
Ski, nice sig pic...boy does that baby transfer!! :smash: :reddevil Wait'll that CORKY style MOTOR goes in! :reddevil :crazy: :crazy: :chevy
Old Nov 22, 2002 | 06:05 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Yeah hopefully there will be about 4 inches under the front tires then....but that is doubtful. If there is, then there will probably be chunks of the rear laying behind :eek:
Old Nov 22, 2002 | 06:30 PM
ralph's Avatar
ralph
Default Re: SR install (ski_dwn_it)
yeah, i split my harness up into 2-3 groups and retaped them with that silver heat tape. then stuffed them between the runners and the fuel rails. I also cut some of the webbing out of the base and turned some of the injectors so they would plug in from the inside. Just hope i never have to pull of the harness, cause the plenum would have to come off. After two years like that...no problems (except the time i drilled thru the harness, but that's another story).
To SR install
