No power
Old Apr 6, 2020 | 07:07 PM
MarkB85vette's Avatar
MarkB85vette
Default No power
Hello all,
Finally got the car running due to a fuel preasure regulator vacuum line break. Have been working to get the timing right. The book says 6°BTDC, but 10° is firing better. If I accelerate slowly the cars moves and shifts pretty well. If I step on it there is no power. Not sure what to do next. Any advice would be great. My name is Mark and I live in Corpus Christi Texas. I hope all of you out there are ok with all the caronavirus stuff going on. Look forward to your advice. Thanks
Old Apr 7, 2020 | 07:12 AM
GregMartin's Avatar
GregMartin
Originally Posted by MarkB85vette
Hello all,
Hey Mark
When you set the timing did you have the EST connector disconnected? If not your engine will be about 10 deg retarded.
Old Apr 7, 2020 | 07:19 AM
MarkB85vette
Thanks for the response. Yes I did have the EST disconnected. I took her for a test drive and forgot to reconnect t
Old Apr 7, 2020 | 07:21 AM
MarkB85vette
Forgot to reconnect the EST, so the next morning I plugged it in, but still nothing. I played around with the timing and got it running much better, but still no power when I had the throttle wide open
Old Apr 7, 2020 | 07:24 AM
MarkB85vette
I suppose that fuel preasure test is in order. I gave a new fuel pump, fuel filter, plugs and wires. New distributor as well. I have run new vacuum lines, but my local auto parts store was out of the larger diameter vacuum lines
Old Apr 7, 2020 | 07:43 AM
GregMartin's Avatar
GregMartin
Yeah could be fuel pressure but it could be a lot of things. Can you hook up a scanner something like an old Tech 1 tester would work or WinALDL on a PC. Is you TPS adjusted and working correctly? Any advice is really a guess without data. Also if the engine is running when you connect the EST you have to switch off and on again before the ECM will take control of the timing.
Old Apr 7, 2020 | 07:59 AM
MarkB85vette
Greg,
Thanks for the support. Not sure if the ECM is even working. The guy I bought the car from had installed a new gauge cluster, and nothing on the dash comes on. All of the fuses are good, so I have to find where he disconnected the rest of the dash power. ECM, is that an Electronic Computer Module? So I will go back through, confirm timing, and shut off the motor before connecting the EST. Is 10° BTDC too far? Also, when I move my distributor it is to the left that is advancing. I thought right advance, left retard. I have mostly owned Fords or imports. With the C4 left advances.
MarkB85vette
Also, what is the TPS?
Old Apr 7, 2020 | 08:36 AM
GregMartin's Avatar
GregMartin
Ok turning the distributor body anticlockwise will advance it because rotor turns clockwise. So you disconnected the EST and set the timing to 6 deg BTDC but anything out to 12 deg BTDC will work. Then reconnect the EST but the timing won’t change. Switch the engine off then on and your car should idle around 20 deg BTDC. The timing advance is now being managed by your engine management computer referred to as an ECM in that model corvette. Your ECM will definitely be there and working because the engine won’t run without it, it controls your fuel injection system as well as timing advance. TPS stands for throttle position sensor.
Sounds like you are just starting your corvette journey so my first bit of advice is to get a genuine GM factory service manual FSM if will be very helpful when it comes to fault finding.
Edit: the LCD dash panel has two multi pin connectors on the right hand end of the unit.
Old Apr 7, 2020 | 08:46 AM
MarkB85vette
Greg,
Thanks, yes I am new to Chevys. And I will walk the car back through the timing process. I have done a few minor restorations, but they were Fords with carbs. When I decided to get my first Vette the C4s seemed like a good first choice that I could afford. I have a Chilton manual but it is very general over all. Can you recommend a good source for a shop manual for my C4? I have looked on line and the options are all over the place. I will let you know how it goes. I hope to get some time to work on her this afternoon. I hope your family is well, and I will be in touch.
Old Apr 7, 2020 | 09:01 AM
GregMartin's Avatar
GregMartin
I bought my FSM on eBay. I just had a quick look and found this link but others might have better options
https://www.ebay.com.au/itm/362709919678
You take care as well. The corona isn’t as bad where I am in Australia at the moment, but we are all working from home and lots of businesses are currently shut. We are self isolating, bars an restaurants are shut I guess it’s going to be a pretty boring Easter .
Old Apr 7, 2020 | 11:31 AM
Theman5's Avatar
Theman5
Throttle position sensor
Old Apr 7, 2020 | 01:01 PM
MarkB85vette
Thanks for the link. I will let you and everyone know what happens after I reset timing and then move forward.
Old Apr 7, 2020 | 10:55 PM
MarkB85vette
Ok, here is what I figured out about my C4. Timing seems good, 10°BTDC. Fires right up, but when you rev the motor at 4000rpm, the motor seems to fall out. Almost like there is a governor. Thoughts
Old Apr 8, 2020 | 03:39 AM
GregMartin's Avatar
GregMartin
Does it have power below 4000. Have you put a timing light on it when you are reving it and if so does the timing advance when you rev it?
Old Apr 8, 2020 | 07:55 AM
MarkB85vette
There does seem to be power up to 4000. I have not put a timing light on it during rev up. I will probably do that today. I will let you know what I find out. Thanks again Greg
Old Apr 8, 2020 | 08:06 AM
GregMartin's Avatar
GregMartin
if it’s got power down low and the timing is advancing then I would suspect fuel pressure. There is a schrader valve on your fuel rail where you can check the fuel pressure. But it’s kind of still anyone’s guess at this stage.
Oh and no worries Mark happy to help but I haven’t come up with anything useful yet.
To No power
Old Apr 8, 2020 | 11:47 AM
MarkB85vette
We and U will figure it out. I am teleworking as well so when that ends I can get to the vette. You are a day ahead as well. It is Wed at 1042 am here
Old Apr 8, 2020 | 11:48 AM
MarkB85vette
We and I*
Old Apr 8, 2020 | 06:20 PM
GregMartin's Avatar
GregMartin
Yeah you’re speaking to a voice from the future
