LT4 rod bolt torque specs
Old Apr 25, 2020 | 04:27 PM
Furias15x's Avatar
Furias15x
Default LT4 rod bolt torque specs
I am going through the specs prior to starting. Reading up on assembly prior to starting. Its always good to be as informed as possible before diving.
On the rod bolts it says to torque to 20 lbs on the 1st pass then 55 degrees on the second pass. I don't have the tool that will measure the degrees. Is there a standard torque spec for the second pass on the rod and head bolts? Or should I order this tool and wait?
Seems like every time I turn around I have to go get a tool.
Thank you
Doug
Old Apr 25, 2020 | 07:35 PM
rjacobs's Avatar
rjacobs
they are TTY bolts so the degree measurement is really the correct way to do it.
Autozone sells the tool for 10 bucks
​​​​​​https://www.autozone.com/test-scan-a...uge/141510_0_0
Oreilly might sell it too.
Old Apr 25, 2020 | 08:01 PM
Furias15x's Avatar
Furias15x
Oh cool thank you!!
To LT4 rod bolt torque specs
