Wheel Spacers
I purchased the spacers here: https://www.ebay.com/itm/2X-20mm-5x4...72.m2749.l2649
The other option is adapters. They bolt to the factory hub and then have new lug studs to bolt the wheel to. Torque the lugs on the adapter just like you do a wheel. Then torque the wheel onto the adapters. I've been using 3" wide adapters on my 73 and 76 for nearly 20 years with no issues. I put 16, 17 and 18" wheels on my C3s.
The fronts had 8.5" wheels and they fit fine. If they were any wider I think they would have stuck out too far, so I never tried the 9.5" wheels on the front.
The rears had 9.5" wheels and fit fine. They came out to be flush with the outside of the body.
I put them on and then retorqued them after a hundred miles or so. I also retorqued them again after another hundred miles or so and had very slight lug nut movement, so I am glad I did it twice.
I ran these wheels for a few thousand miles and never had any issues.
Good luck.
My '85 with adapters and staggered late wheels is shown below.
To the OP's specific situation, the early 16x9.5 wheels had 38mm offset, whereas the later 17x9.5" had 56mm offset. That's a difference of 18mm, or about 3/4", which tells you the thickness of the spacers you're looking for. You have plenty of room on the outside (assuming a 275/40/17 tire, which is what you should use on that size wheel) to use a 1" spacer if you prefer. It will look a little more aggressive that way, at the expense of a bit more scrub radius. So anywhere from 3/4-1" spacers are what you want. You'll want longer wheel studs, and ARP (among others) has those readily available. They aren't hard to install.
ETA: If you're looking at staggered-width set of later wheels with 8.5" fronts, then the early 16x8.5 wheels had an offset of only 32mm, whereas the later 17x8.5 (93-96) still had 56mm. So in that case, you have a 24mm difference in offset, so you should look for 24mm or 1" spacers for the front, and probably 3/4" for the rear if you want to keep the outside edges of the wheels in the stock locations for your 85.
