early C4 dash
Old Nov 24, 2002 | 02:49 AM
1985calcorvette's Avatar
1985calcorvette
Default early C4 dash
ya. does the dash get brighter at night? At night, might dash is verryyyy faint.so faint i cant see it. Would it require a rebuild to get it back working correctly?
Old Nov 24, 2002 | 03:59 AM
VQT88Vette's Avatar
VQT88Vette
Default Re: early C4 dash (1985calcorvette)
Try shining a flash light to the sensor on the top left corner of the dash to see if it still working. If it does, your dash should brighten up a bit. Beside that I guess you need to repair the dash. There is a site from Baytee (sp) showing how to fix this. It may even be in the tech tips sectionon top under tools.
[Modified by VQT88Vette, 4:05 AM 11/24/2002]
Old Nov 24, 2002 | 07:54 AM
LD85's Avatar
LD85
Default Re: early C4 dash (VQT88Vette)
:thumbs:
Old Nov 24, 2002 | 06:23 PM
MagRed_04's Avatar
MagRed_04
Default Re: early C4 dash (ld85)
Check the fuse that runs to the brake lights and fog lights... Mine did that once and it turned out that the fuse was blown.
[Modified by Vette_Crazy, 6:23 PM 11/24/2002]
Old Nov 24, 2002 | 06:51 PM
Tourney3p0's Avatar
Tourney3p0
Default Re: early C4 dash (Vette_Crazy)
I think it's the Inst fuse that you should look at. When you're under a fair amount of streetlight at night, can you faintly see it? And when it's pitch black out is there no display at all? If that's the problem, look at the Inst fuse. If it's good, check out the optical sensor.
Old Nov 24, 2002 | 09:04 PM
1985calcorvette
ya. under bright street lights i can barely see it
Old Nov 24, 2002 | 09:18 PM
Tourney3p0's Avatar
Tourney3p0
And it looks fine in broad daylight? Definitely check the Inst fuse and replace as necessary. If it's fine then try the sensor test as mentioned above. If you shine a light into the sensor and it brightens up considerably then replace the optical sensor.
Old Nov 24, 2002 | 10:34 PM
Juliet's Avatar
Juliet
Default Re: early C4 dash (Tourney3p0)
The light sensor in my '87 seems to have a bit of a time delay on it - so you might need to shine the light for 30 or 45 seconds before you see the dash respond. Same if you cover up the sensor before you see it dim. Also, have you checked the brightness via turning the light switch ****? Does it respond at all there (again with some time delay - at least on mine that's how it is). ~Juliet
Old Nov 25, 2002 | 12:32 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Default Re: early C4 dash (Juliet)
Yeah, I guess it does get brighter at night. This is interesting, as most stereo's I've ever installed dim at night. (It takes less LCD brightness to see it at night). I don't see why the Corvette is different. I have trouble seeing mine in the daytime, especially with my shades on. Mine also gets brighter when I'm pushing high rpms, I assume this is from the big charge put out by the alternator.
To early C4 dash
