Starter motor
Old May 4, 2020 | 10:25 AM
C4doug's Avatar
C4doug
Cruising
Default Starter motor
Good morning. My first post/ question. When I turn the key on my 95 LT1 with a new battery I get a click and the daytime running lights go out. Without turning the key off I try again and the starter engages and starts. Sometimes I can here the starter spinning but it doesn’t connect with the fly wheel. Should I pull the starter and have it tested?
Old May 4, 2020 | 10:56 AM
Kevova's Avatar
Kevova
Yes, Spinning and not engaging would be something with the starter.
Old May 4, 2020 | 10:58 AM
C4doug's Avatar
C4doug
Cruising
Thanks for the reply. I’ll remove it and have it tested.
Old May 4, 2020 | 11:11 AM
s carter's Avatar
s carter
Before you pull the Starter I would, would Disconnect the Battery Inspect for Corrosion on Terminals reconnect and Tightly and see if fixed. If Not disconnect Battery Recheck all Connections Below, and try again if still a problem Pull it.
Old May 4, 2020 | 11:12 AM
Kevova's Avatar
Kevova
Look at ring gear teeth when starter is out. Be sure there is no unusual wear.
Old May 4, 2020 | 11:33 AM
C4doug's Avatar
C4doug
Cruising
Will do. Thanks
Old May 4, 2020 | 11:35 AM
mtwoolford's Avatar
mtwoolford
Generally, bench "testing" only tests two things; the solenoid, which will move the gear teeth outward to engage the flywheel while simultaneously closing the high amperage circuit to the starter motor itself, and the brushes / communtator on the starter armature. If all is well, the starter will turn over; usually this is considered enough, i.e. if it fails this test, it needs repair / replacement. But what it doesn't test is the small internal clutch attached to the pinion gear itself; sometimes a starter will engage, and turn over, but the engine fails to turn over. In this case the drive clutch on the starter needs replacement.. Another thing that a "bench" test may or may not reveal is where the armature bearings / bushings are worn out and the armature is rubbing against the stationary windings in the case; in a "no load" condition the starer may rotate on the bench, but the added drag, plus the added load of turning over the engine, may prevent the starter from turning the engine over. If you have a reduction gear starter, these problems are multiplied by the added complexities of the reduction gear train.
Old May 4, 2020 | 02:52 PM
playsdixie's Avatar
playsdixie
welcome to the forum....lots of good advice and help here.......If you have to bite the bullet and put in a new one, look at those gear reduction starters....they're a lot smaller and work great.....my 85 had a mammoth one and putting that little thing in was easy and it works terrific....starts in a miili-second
Old May 4, 2020 | 03:54 PM
C4doug's Avatar
C4doug
Cruising
Thanks for the info. I’m taking it to an auto electrical shop to have it diagnosed.
Old May 4, 2020 | 03:55 PM
C4doug's Avatar
C4doug
Cruising
Thanks for the advice. I’ll check that out.
To Starter motor
