84 corvette replacing fuel injector question
Old May 5, 2020 | 10:18 PM
Nickydowns's Avatar
Nickydowns
Default 84 corvette replacing fuel injector question
Do I need to bleed any fuel or can I just take too piece off of the injector and pull injector out and replace or is fuel gonna go every where?
also standard fuel injectors or ac delco?
Old May 6, 2020 | 09:10 AM
GregMartin's Avatar
GregMartin
no nothing to bleed, fuel won’t go every where. I assume you have a gasket set because you will need to replace the top gasket if you remove the top plate of the throttle body. The front and rear fuel injector have a different flow rate and are not interchangeable. There is a top and bottom o ring that should also be replaced. Again the method of extraction is described in the FSM if you don’t have one get one. But basically it goes like this, lay a screwdriver across the top of the throttle body to leaver on. Take another screwdriver and put the blade under the ridge on the top of the injector. Leaver against the other screwdriver and pop it out.
Old May 6, 2020 | 09:13 AM
Nickydowns's Avatar
Nickydowns
Thanks again I see 2 different ones tho I can get standard which comes with gaskets or I can get ac deco replacement but I need to buy gaskets in the side.
Old May 6, 2020 | 09:18 AM
GregMartin's Avatar
GregMartin
Either of those will be ok just remember the front and rear are different.
To 84 corvette replacing fuel injector question
