Anyone have experience with code 26?
Nov 24, 2002 | 02:17 PM
I've been getting this recently, how did you fix it. What's the chance of it being the ECM?
Nov 24, 2002 | 02:19 PM
Re: Anyone have experience with code 26? (Dudeurgettnavette)
This sounds familiar. Which one is 26?
Nov 24, 2002 | 02:26 PM
Re: Anyone have experience with code 26? (scorp508)
If your code 26 is the same as my 92, it's circuit # 1 quad driver. It controls the Canister purge sol. , EGR sol. and AIR relay.
Nov 24, 2002 | 02:34 PM
On a 92 there is a Code 26 in the CCM. It says LCD Blanking Control Circuit Shorted to B+ or CCM Internal Open.
In the SIR (air bag) System, a Code 26 is an Open in Steering Column Circuit.
How are you determining the codes?
Ooops, ittlfly is right!! The ECM Code 26 is the QDM module. Are you getting an SES light?
[Modified by c4cruiser, 11:38 AM 11/24/2002]
Nov 24, 2002 | 02:36 PM
Re: Anyone have experience with code 26? (c4cruiser)
I recovered the code by doing the paper clip trick.
The EGR solenoid has just been replaced, before its replacement I was still getting the code, so I dont think its the EGR solenoid.
[Modified by Dudeurgettnavette, 1:42 PM 11/24/2002]
Nov 24, 2002 | 02:45 PM
The Check Engine Soon light comes on.
Nov 24, 2002 | 04:57 PM
Have you checked to see if all 3 relay/solenoids work?... AIR, canister purge and EGR?
Nov 24, 2002 | 05:33 PM
Re: Anyone have experience with code 26? (ittlfly)
It was a siezed air pump and the canister purge valve on mine. Both easy fixes, but the airpump was mucho expensive. try Jeff Kopp
Nov 24, 2002 | 05:35 PM
Re: Anyone have experience with code 26? (HiRiser)
PS the electric airpump has a big fuse on the top of it, (30 amp) check that first
Nov 24, 2002 | 06:02 PM
I've only checked the egr solenoid. Now if it wasn't cold and I wasnt lazy I'd get my butt out there and work :mad
Nov 24, 2002 | 06:20 PM
Once you check it out , let us know what you find out.
Nov 29, 2002 | 06:29 PM
Turned out to be a Canister purge solenoid. :crazy: Car runes better now too :D Thanks for the help everyone!
