No fuel pressure.
Old May 19, 2020 | 11:11 AM
Nomake Wan's Avatar
Nomake Wan
May be a silly question, but you've confirmed ignition timing is correct with a timing gun?
Old May 20, 2020 | 03:11 PM
DubieDc's Avatar
DubieDc
Cruising
that’s the next step I was going to take after testing if the injectors spit fuel or not. It may be worth mentioning I installed Acel spark plug wires which I don’t think would make a difference.
Old May 23, 2020 | 02:34 PM
DubieDc's Avatar
DubieDc
Cruising
I GOT IT RUNNING! After a proper tune up replacing the fuel pump, sending unit, relay, plugs/wires,starter the fuel is fixed and I connected a wire I discovered was disconnected (still not sure what it is orange wire off red batt terminal going into what appears to be a vacuum Line) the 85 is now back on the road and running great! Huge thanks to everyone that helped out you guys are great!
Old May 23, 2020 | 08:27 PM
Nomake Wan's Avatar
Nomake Wan
Woohoo!! Congrats on getting it back on the road!!
