'86 head upgrade questions
1. the motor has about 97000 on it. It has good compression and vacuum. The valve seals a going so I get a little smoke randomly on startup but nothing more. Is that mileage too high for a head upgrade or should I be considering the whole motor build at this point?
2. Debating between Edelbrock E-Streets and Vortecs with a SD lower intake. The Eddys will save some money since I can reuse my stock lower intake but I've read that they have some quality issues, particularly in the valvetrain. I'm leaning toward to Vortecs/SD intake.
3. Will I need a tune for any of this or will the stock computer handle it? I'm not changing out the cam but may consider headers down the line. Currently using a catless y-pipe, main cat delete and Walker Quiet Flow mufflers.
Definitely happier with low rpm torque over a high rpm screamer.
Thanks for any thoughts.
truth is i wouldnt bother unless the car is setimental to you. if u r after more jam, but an LT1/4/5 car.
but if you really love the 80’s interior (like i do!) then you can do intake (im doing superam), in manifold, heads, cam, valve train, and then and full exhaust. but thats moocho $$$. if you did just heads i dont think u r going to notice much.
My understanding is the intake is the biggest limitation on the L98. If you could open up the sizes of the runners and the intake, I think you release some power. Accel, Edelbrock and AIR seem to be the 3 choices. Also, there are a few types of larger runners - I do not think any are sold new anymore. I hear the super ram is so wide it makes reaching the fuel rail and injectors a problem.
I think the short block is the cheaper part. If you did rebuild the rotating assembly, a 383 is just about the same cost and releases some power, but it will also make the intake more limiting.
These are the things on my mind, Would love to hear the gurus here expand on your question.
Many say if you put new heads on it will blow the car up..well if they are leaning hard on an old engine playing with newfound performance well....lol Youll be fine
tpi421vette can get you hooked up with the afrs reasonable.
Those and a better base/runners and headers will really wake it up.
