91 ALDL pinout.
Old May 10, 2020 | 02:41 PM
dm575's Avatar
dm575
Default 91 ALDL pinout.
Can anyone tell me which pin provides serial data on my 91 L98. I'm hoping to get Tunerpro running for any future diagnostics that are required. I'm in the UK so expertise is not easy to find.
I have an FT232 USB - Serial converter and an ALDL plug which only appears to be wired to pin M ( 8192 baud )
Any advice much appreciated ( I have searched but not found the answer anywhere )
Old May 10, 2020 | 07:17 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Here they are for my '88:
Upper Row (right -> left)
A - Gnd
B - Test
C - Air Pump
D - Check Engine
E - Serial Data
F - TCC Clutch
Lower Row (right -> left)
M - Serial Data
L - NC
K - NC
J - NC
H - NC
G - Fuel Pump Test
Old May 10, 2020 | 07:26 PM
Nomake Wan's Avatar
Nomake Wan
For your '91, serial data will be on M at 8192 baud. E, if populated, is the old 160 baud serial data format and should not be used. A is GND, as 65Z01 stated. Good luck!
Old May 11, 2020 | 12:41 AM
dm575's Avatar
dm575
Thanks for the replies. Hopefully the cable I have made up will work then. Here I go with learning TunerPro
To 91 ALDL pinout.
