I need to remove the radio face plate on my 94. Does it just pull off, or do I need to disassemble something else first. Thought I'd ask the question before I broke something.
From: No more yankee my wankee, the Donger is tired!
Re: Radio face plate (vette_guy)
Open up your cold the shifter plate down. Remove the ashtray. Remove the screw there. If you hjave a manual tranny, just put the shift lever into 4th and lift up on the console and leave it loose. Auto...I have no idea. Should be similar.
Then remove the two screws at the base of the radio face plate. Then you really need to remove the A/C vent to make sure you don't tweek anything. It should have two screw in it as well. Then tug on the radio plate and it will come off. Install reverse of removal.
