I need help
Old Nov 24, 2002 | 08:05 PM
jakelane's Avatar
jakelane
Default I need help
can someone please look these codes up for me??? i posted this in scan-n-tune and no one responded
15
24
34
36
44
TIA
Old Nov 24, 2002 | 08:08 PM
Red Dwarf's Avatar
Red Dwarf
Default Re: I need help (jakelane)
go here.......http://www.c4vettes.com/
Bill-35thAnvrsy-88's Avatar
Bill-35thAnvrsy-88
Just do a search in the search section and you will find more than enough on each one I am sure!
Good Luck
Old Nov 24, 2002 | 08:12 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Here ya go:
15=coolant temp sensor high voltage == replace it
24=vehicle speed sensor (VSS)==??
34=MAF too low
36=MAF burn-off problem, replace the relay (may cure #34 too)
44=lean exhaust==maybe O2 sensor problem
Replace the coolant temp sensor in the front of the block under the TB and the MAF burn-off relay, clear the codes and see what comes back after a teset drive.
Then use the method on my site to see if the ECM is going into closed loop mode.
Old Nov 24, 2002 | 08:14 PM
jakelane's Avatar
jakelane
Default Re: I need help (65Z01)
thanks guys
Old Nov 27, 2002 | 06:06 PM
Mike_88Z51's Avatar
Mike_88Z51
From: Sacramento, CA Money can't buy happiness - but it's more comfortable to cry in a Corvette than a Yugo.
Sometimes when you are getting a bunch of codes at once it is due to a bad (or going bad) ECM. It can also be due to a bad electrical connection to the ECM.
Disconnecting the battery for 30 seconds will clear all codes from the ECM. I'd replace the MAF relays with replacements from NAPA. The NAPA replacements will be duplicates of the GM units at about 75% of the price.
Then I'd do as 65Z01 says, test drive it a bit and see if the codes come back.
To I need help
