1996 turn signal question
Old May 17, 2020 | 02:26 PM
Furias15x's Avatar
Furias15x
Default 1996 turn signal question
Hello,
Replaced bulbs, front and back and the cornering bulbs.
Lights on, turn on left signal, blinker bulbs go solid, cornering light on the front comes on and cornering light on the rear does not.
Lights off, turn on signal, blinker bulbs go solid.
Same issue on the right side. Do I have the wrong brake bulbs?
Brake lights work.
WTH??
Old May 17, 2020 | 03:49 PM
Furias15x's Avatar
Furias15x
update: went to parts store had them look up the bulb numbers instead of trusting what was in the car.
Got the right brake light bulbs and turn signals. They are not working!
But the rear cornering lights don't come on when the blinker is turned on. They didn't have those bulbs and the bulbs in there fit and are not burned. But still they could be wrong ones.
Will check later.
Old May 17, 2020 | 05:15 PM
Kevova's Avatar
Kevova
What the bulb numbers you have installed and location.
turn signal bulbs are dual element 1 for stop/turn function the other is for running lights. The bulbs use a common ground. If socket ground circuit failure leads to feedback.
reverse, high level stop, cornering, and side marker are single element bulbs.
Old May 17, 2020 | 09:08 PM
Nomake Wan's Avatar
Nomake Wan
You didn't try to swap to LEDs or something did you?
All four of the taillight bulbs are 1157s (dual-element, as Kevova said). Front turn signals are also 1157s, just amber.
Your car doesn't have "rear turning lights." It has red corner bulbs (#24) that come on with the parking lights and headlights, and it has side-facing reverse light indicators (1156). That can be confusing since there are similar-looking assemblies on the front that do come on with the turn signals (#24 blinks in time with the front signals with the parking/headlights off, and out-of-time with them with the parking/headlights on; 1156 comes on with the turn signals if the parking/headlights are on).
Good luck.
Old May 17, 2020 | 11:56 PM
Furias15x's Avatar
Furias15x
Its all working now. The only bulbs I haven't checked yet are the side reverse lights. Those cant be checked yet as the transmission is out of the car.
I used the standard bulbs that the clerk at autozone looked up in the parts list. They all worked. Amazing huh?
To 1996 turn signal question
