Supercharges and VE curves (Speed Density)
Old Nov 25, 2002 | 08:22 AM
89vette's Avatar
89vette
Default Supercharges and VE curves (Speed Density)
I have been thinking about this and can't figure it out. If you have a car that is supercharged the pressure in the motor is higher than the pressure outside. The MAP sensor will show 100KPA at atmospheric pressure which is what the pressure is under WOT in an N/A motor. Now lets say that you introduce 10 pounds of boot pressure. Now the pressure is higher than atmospheric. How does the MAP sensor measure this? Is that what a 2 bar map is for? I’m trying to get an idea how this works with the VE tables only accepting values as 100 max. I’m assuming that with a 2 bar map all the values are cut in half. In other words, where in your N/A VE table if you had a value of 90, with a 2 bar map this would be 45. Is my assumption correct? If so how do the timing tables work and all the other tables that use MAP voltage for calculations? I have a few years experience with the $6E code and $8D code but all N/A applications.
Thanks,
Jason
Old Nov 25, 2002 | 02:12 PM
dgoodhue's Avatar
dgoodhue
Default Re: Supercharges and VE curves (89vette)
Yes that is what a 2 bars map is for. The map sensor volatge is scaled over 2 bar vs 1 bar (or in half as in your example) I am not really sure though how the over the counter 1 bar 90-93 C4's with a S/C would properly fuel itself other than a FMU.
Old Nov 26, 2002 | 11:58 AM
MarkBychowski's Avatar
MarkBychowski
I'm very interested in this as well. I found some interesting discussions on th e LT1-edit archive http://www.lt1edit.com/pipermail/lt1edit/ You can download it -- it's a huge text file of all the e-mail discussions, search for 'bar'. I was hoping it was as simple as installing a 2-bar MAP, then scaling all of the tables appropriately, but it doesn't appear to be that easy. Hopefully someone with experience will chime in here!
Old Nov 26, 2002 | 03:37 PM
dgoodhue's Avatar
dgoodhue
Default Re: Supercharges and VE curves (MarkBychowski)
On the Syclone/Typhoon ECM someone has made converted bin from a 3 bar MAP from a 2 bar, I know that the their was more than scaling of the map sensor to make it work properly. I think some of the other function are affected as the MAP sensor is used in a lot of different calculations.
Old Nov 26, 2002 | 04:13 PM
89vette's Avatar
89vette
Default Re: Supercharges and VE curves (dgoodhue)
I see how they are doing it. Its basically a tuning no no. They are reducing timing and adding fuel in the PE vs RPM table. Looks pretty easy now. I guess with intercooled motors alot less timing needs to come out. You can also reduce timing with a boost retard box.
Old Nov 26, 2002 | 06:16 PM
BOWTYE8's Avatar
BOWTYE8
I belive Shalin(blownc4) was running his 93 SC'd vette with the ECM only. Not sure what map sensor. I have heard that his car ran and drove extrtemely well.
Dennis
To Supercharges and VE curves (Speed Density)
