Zr1 Headlight motor
2. Pulled it our again , made new brushes and back in it goes.. no luck.. Now what..?
3. Measured plug - no voltage..
4. Checked fuse - fuse is OK
5. Jumped a cable from the working headlight to the other - stared to turn, but would now both would not turn to the end unless helped.. Myabe too much amp for 1 relay? After removing the jumper cable, the other turs as it should.
6. SO I am thinking maybe when brush broke, shorted something and somehow damaged a relay.. or the headlight module..
I am not electrician, so sorry if my logic is not correct or smthng...
Are there relays at all that give voltage to the motors or is it the headlight module? I saw the latter in the SM so maybe I need to have the module checked for soldering cracks or elements burned?
Any advise would be much appreciated.
In short - busings solved, new motor brushes - ok.. motor is working when given voltage... , no voltage for the motor on the headlight plug
