Headlight Motor
Old Nov 25, 2002 | 10:55 AM
Kehrer923's Avatar
Kehrer923
Default Headlight Motor
My headlight will flip about halfway up then stop. If i help it along the way and will go all the way and stay, but otherwise it just stops halfway. Also, if i just turn on the fogs when i turn the lights off the motor keeps running for a while.
Old Nov 25, 2002 | 11:20 AM
VetBoy89's Avatar
VetBoy89
Default Re: Headlight Motor (Kehrer923)
Sounds like it's time to go to http://www.ecklers.com and buy (2) packs of p/n: 29304. They are the three bushings for each motor. They are about $5 per pack and you may as well do both because if one side is bad the other side is right behind it.
There is a good article in tech tips on the procedure, it's real easy... :smash:
https://www.corvetteforum.com/techti...D=16&TopicID=2
Cap'n Rich's Avatar
Cap'n Rich
See http://forums.corvetteforum.com/zerothread?id=352935
Rich
Old Nov 25, 2002 | 11:27 AM
Cap'n Rich's Avatar
Cap'n Rich
Default Re: Headlight Motor (VetBoy89)
The mail order suppliers also charge another $5 or so to ship them to you. Total? ~$15. Home Depot and Lowes carry the bushings for about 15 cents each - You'll need 6 to rebuild both headlight gearboxes. Total? ~$.90 + tax.
Your call.
Rich
Old Nov 26, 2002 | 09:44 AM
PTz-92-LT1's Avatar
PTz-92-LT1
Default Re: Headlight Motor (Cap'n Rich)
I agree with the posts above which suggest the bushings might be the issue...however here is another possibility. When I attempted to fix mine it was the nylon gear that was gone. I replaced it with the brass one seen in the catalog. That was 2 1/2 years ago and they still work as designed.
Old Nov 26, 2002 | 11:11 AM
Cap'n Rich's Avatar
Cap'n Rich
Default Re: Headlight Motor (PTz-92-LT1)
Good point. If he follows the procedure for disassembly given in the tech tip, the condition of the gear will be evident upon its removal.
:yesnod:
Rich
To Headlight Motor
