84 corvette gas peddle question
Old May 20, 2020 | 07:59 PM
Nickydowns's Avatar
Nickydowns
Default 84 corvette gas peddle question
Was just being nosy and I put my foot under the gas peddle and just kinda played around and hit the peddle under it and noticed it seems loose. Like if you were to pull it back like reverse instead of push down it seems loose. Is this normal?? But if I push regularly down it’s fine isn’t loose. Anyone else notice this or want to check if it seems looks if u put your hand behind the gas peddle and push backward?
Old May 21, 2020 | 02:47 PM
383vett's Avatar
383vett
It's normal for the gas PEDAL to do that.
