a/c/fan 1985
Old May 22, 2020 | 04:57 PM
playsdixie's Avatar
playsdixie
Default a/c/fan 1985
Although I live in S Fl, don't use the a/c much....keep the roof off and drive when it's cooler.....recently put the roof back on, now it doesn't seem like the fan is blowing like I remember....it's blowing but doesn't seem right to me.....any further tests to see if I need a new one other than this observation?.....big deal to put one in? thanks, Paul
Old May 22, 2020 | 05:26 PM
bartenderfloyd's Avatar
bartenderfloyd
I can't help with diagnosing the issue but as far as replacing the squirrel cage fan assembly it is cheap and easy. I think only 5 screws holding it in. There might have been a hose in the way and I had to take out a few screws from the fender well to get room but the whole job took a half hour. You may want to check the relay first. It is located directly below the blower motor. Mine was stuck on high. Replaced it and now it works beautifully.
1985 Corvette
Old May 22, 2020 | 08:37 PM
playsdixie's Avatar
playsdixie
1985 Corvette
thanks, being in S Florida this time of year, I could live with just "high"......
Old May 22, 2020 | 11:41 PM
xrav22's Avatar
xrav22
Make sure your air is not going past the accumulator tubes and cooling the engine. My seals or caulk was cracked and I had to put sealant around them. Good Luck!
Old May 23, 2020 | 08:48 AM
playsdixie's Avatar
playsdixie
did some research last night...don't believe the relay could cause the fan not to work on "high" only......gonna keep checking.....at least it works and does cool the car, but not a quick anymore.....blasted hot down here now.....
Old May 23, 2020 | 10:05 AM
BillDurant's Avatar
BillDurant
in Florida too, my ac blows too lightly doesn't coll the car I think blend doors don't work
heat / ac buttons stuck also
Old May 23, 2020 | 11:28 AM
xrav22's Avatar
xrav22
I thought you had a low fan problem. When I bought my car it only worked on high, which is default when it is bad. I took off the resistor connector and cleaned it good with electrical cleaner and it has worked normally since 2014. Mine was above the ac in the engine bay.(85).
Old May 23, 2020 | 12:26 PM
playsdixie's Avatar
playsdixie
Yes, it works on low, med....as I recall there were 4 speeds...not sure....high does not work.....from my research, it's a bad relay if it "stays" in high......I'll keep looking.....not even really summer yet here.....the air is cool, med will cool it, not to my satisfaction....used to work so good it always reminded me of the U>P> of Michigan where I'm from.....not really hot up there along lake Superior.....
Old May 23, 2020 | 11:01 PM
ACMX92's Avatar
ACMX92
2026 Restomod of the Year Finalist
2026 Corvette of the Year Finalist - Modified
2025 C4 of the Year Winner - Modified
2021 C4 of the Year Finalist - Modified
Most likely a blower motor resistor if you have lost one or more of your fan speeds. My 85 would only work on high. Ordered a replacement resistor from rockauto and swapped it out quick and easy.
Old May 23, 2020 | 11:34 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default Fan
I had to change the motor because it was making a bearing noise.
new motor was around $30 at autozone, about 10 years ago.
i have the auto controller in the dash, and it works based on the “programmer” At the base of the steering column up by the pedals inside the car.
its electropneumatic, as it has electrical coils that control the vacuum to different features in the heater system
To a/c/fan 1985
