Oil cooler options
Also, oil that was in there thinned out a bit. Some fuel dilution from the really fat base tune etc. That may help some too now that the tune is pretty spot on to stoich.
i never did come back to update that thread after taking it to the track. i never saw over 119C HARD HARD HARD track driving in 30 minite intervals. That was with a cleaned rad, open cat, and kc4. It definitely regulates the oil.
That said, my zr1 with an external cooler ...I NEVER see oil hotter than 95c.
go for the external oil cooler!!!! it will work!
No factory oil cooler, keeping the rpm over say 3600 for an extended period at low speeds during the summer cooks my oil pretty good.
Adding an oversized filter, and sheielding that filter from my headers helps a bit, but the temps can still shoot up and over 260.
I had it hit 294 per the temp gauge one summer, stuck in traffic, and something like 105F outside.
I also have issues with my coolant temp, but i believe my transmission/loose converter is to blame since i still have it running through the radiator.
Soon to be separated.
The only thing i really worry about with an after market cooler, is when it's cold out.
I don't want to over cool, so some sort of temp controlled bypass would be awesome.
Something i have an issue with on my S10, during the winter i like to tape off my transmission cooler so only 25% of it is open.
I would like to see what you figure out, since it's going to be a while before i start messing with it on my car.
ETA: For the thread, I also have a "mild" flat tappet cam.
Exhaust: Same type, headers (ceramic coated inside and out), and 3in exhaust.
My trans cooler is just a single pass, but nearly the size of my radiator.
My trans temps still get up there pretty good, I'm going to add a much higher quality cooler later on.
I have one that i bought to use with my air compressor to help cool and dry the air coming out, but i decided i don't need it.
Thank you sir.
I was bouncing between a 10 and 16 row and called a friend and we agreed the 16 would be overkill for how I drive the car. Our spitballed numbers based on the supplied BTU data showed this is adequate. Thanks again. Next up... figure out why my air dam is 2 different sizes lol.
I know prior a good hard rip or two to 6700 would bring it from 200 to 230 in short order and now it actually drops off holds instead of climbing.
But glad to see that temps are under control and you can drive the car without panic attack.
