AC low pressure switch choice
Old May 26, 2020 | 04:41 PM
Dave Witman's Avatar
Dave Witman
Default AC low pressure switch choice
92 vette the low side pressure switch is sticking or intermittent. I need to replace parts house shows a black or a green switch. I have a white. What do these colors mean.
Old May 26, 2020 | 07:13 PM
Dave Witman
yes it has two very small pins recessed inside housing.
Old May 27, 2020 | 03:53 PM
Dave Witman
ok found this switch at napa TEM 207468 which fit and had r134 pressure settings. All is working better now. Compressor does not cycle nearly as much it did before. Thanks for all your help you got me going on the right track. I really like the use of an adjustable switch be this was low mileage car and is still all original except for r134 conversion which was done by previous owner.
To AC low pressure switch choice
