Flashing doesnt work, headlight still lighting
Old May 27, 2020 | 12:16 PM
Filip Musil's Avatar
Filip Musil
Default Flashing doesnt work on turn signal
Hi,
Hazard lights flashing, but turn signal just lighting and not flashing
Old May 27, 2020 | 07:50 PM
corvette95's Avatar
corvette95
Bulb out, or relay bad A good service manual will help you greatly.
Old May 27, 2020 | 10:42 PM
jv9999's Avatar
jv9999
Are all the bulbs lighting? If so, probably a bad flasher. It's not the same one as the hazards.
Old May 28, 2020 | 09:39 AM
Filip Musil
All bulb are new and no LED... I thought, that I have one relay for turn signal and hazard... Can you say me where is it? I have 86 convertible... hazard lights I hear under the steeringl wheel on right side.
Old May 28, 2020 | 10:14 AM
jv9999's Avatar
jv9999
It's under the dash. It is not a relay. It's a round silver can with a bi-metallic strip in it. As current flows it heats up. The heat causes it to bend which opens the circuit. It cools, closes, repeat.
Old May 28, 2020 | 02:53 PM
Filip Musil
Ok. Im really really idiot. 2 bulbs doesnt light on side, but they are new. So I have somewhere cuted wire. Can I connect it straight on another wire? Do you know color of wire, which go from behind the car?
To Flashing doesnt work, headlight still lighting
