1992 Corvette Tuning problems
Old Jun 1, 2020 | 12:42 PM
Livewild's Avatar
Livewild
Default 1992 Corvette Tuning problems
To start things off ive been trying to figure this out for the last three days with no advancements. I bought myself a Moates aldu1andcabl1, and Ostrich 2.0, and G1 adapter. Once i got everything i installed all the Moates drivers and tunerprort,Winflash. With the untouched ECM i tried to pull the factory files with winflash and repeatedly got errors. Went onto the moates support page and went threw the trouble shooting guide, using Tunerpro to test the functions of the cable(All functions working properly). But still wasn't able to connect using winflash, after that i tried to use the TunerProsrt data scanner. That kept giving me errors, after trying to trouble shoot them i figure out if i removed all the extra fuses besides the ecm,ccm fuses i got no more errors but the data would have random spazzes and would glitch everything out. I couldn't figure out what was going on so i decided to swap everything over to the Ostrich and load in a bin,xdf,ads/adx file.
Using the files i found threw another thread i used a xdf and a ads file converted to a adx file and uploaded it to the ostrich each of the attached bins seemed to give me some sort or problem between no start or starting and turning off with in a few second. I tried another file which allows me to start and idle but wont rev past 3k as well as with ignition on both fans turn on (high speed) and the odometer reads 0. I found out if i remove the gauges fuse fans turned off and idle smoothed out. Those problems don't occur with the other bins but the car wont run or idle with the other bins listed. Threw out all of the bin swapping also decided to datalog what was going on but now there is no connection with the ecm... I decided to go back into tuner pro and read threw everything and found out that the orignal xdf file seems to be missing half of the flags scalars and tables. After some searching i found another xdf file put that back in tunerprort and went over everything again to see if it would help and no luck.
After all that im stuck and not sure where to go besides trial and error hoping i find a file that works. Any help or guidance id appreciate it greatly!
If anyone happens to have the factory/stock xdf,bin file for a 92 auto($DA2,16159278). A ads or adx file would be great as well so i can figure out whats going on.
Old Jun 26, 2020 | 08:32 PM
searlescm's Avatar
searlescm
Any luck? I found the stock files listed over Geahead-efi.com but I registered for an account yesterday and i'm waiting on approval. I was trying with tunerpro rt, and Aldldroid on my phone but I'm missing the bin files.
Old Jun 26, 2020 | 10:13 PM
Livewild's Avatar
Livewild
Yeah I got it all situated and working I’ll pm ya, if anyone else needs any help regarding my post I’ll be happy to help
Old Jun 27, 2020 | 01:01 AM
searlescm's Avatar
searlescm
Thanks! I appreciate it!
To 1992 Corvette Tuning problems
