Vacuum Question
Old Nov 25, 2002 | 08:54 PM
CLUTCH^Master's Avatar
CLUTCH^Master
Default Vacuum Question
I am trying to find a spot to hook up the vac/Boost line on my 86 L98. Any Ideas??? I have already tryed the tube at the bottom of the throtle body and the two fittings at the back pass. side plentum. Thanks for the ideas in advance. :cheers: :chevy
Old Nov 25, 2002 | 10:25 PM
jakelane's Avatar
jakelane
Default Re: Vacuum Question (CLUTCH^Master)
i am not sure how it hooks up but if it has a "T" then i guess you could hook it up between the pvc valve and the intake, but don't hold me to that....
im sure someone else will chime in here
good luck
jake
Old Nov 26, 2002 | 09:10 AM
CLUTCH^Master
Default Re: Vacuum Question (jakelane)
thanks, I dont want to get oil and emissions in the lines though and i think it may get too hot.(but good idea this may be the only way to do it.
To Vacuum Question
