Largest rim/tire without rubbing!
Old Jun 6, 2020 | 02:10 AM
DennyGriffinJr's Avatar
DennyGriffinJr
Default Largest rim/tire without rubbing!
Greetings All!
Just got my 95 back from the shop. Running a stock
suspension, what is the biggest rim/tire combo that can be used without any rubbing? Both front and rear. Stock just isn't doing it for me.
Would love to see some already existing combos if you don't mind as well!
Thanks in advance.
Old Jun 6, 2020 | 08:54 AM
FAUEE's Avatar
FAUEE
This one is on 24s... That's pretty big.
http://topclassiccarsforsale.com/che...ne-manual.html
Old Jun 6, 2020 | 05:01 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Ouch...
Old Jun 6, 2020 | 07:31 PM
MatthewMiller's Avatar
MatthewMiller
When you say "biggest," do you mean width or diameter?
Old Jun 7, 2020 | 01:24 AM
DennyGriffinJr
After seeing the 24"...width.... DEFINITELY width!!
Old Jun 7, 2020 | 04:32 AM
GregMartin's Avatar
GregMartin
That looks ridiculous.
Old Jun 7, 2020 | 07:21 AM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
on any car
Old Jun 7, 2020 | 07:23 AM
GregMartin's Avatar
GregMartin
Originally Posted by Cruisinfanatic
on any car
yep
Old Jun 7, 2020 | 09:51 AM
FAUEE's Avatar
FAUEE
Good choice.
Old Jun 7, 2020 | 05:30 PM
MatthewMiller
So the short answer for your 95 is that you can run 11"-wide wheels with 315 tires both front and rear as long as you use 50mm offset (which was stock fitment for the rear of a 96 Grand Sport). Going wider that that would involve cutting fenders and adding flares.
To Largest rim/tire without rubbing!
