SLP Torque Converters?
Old Nov 26, 2002 | 08:39 AM
Mr. Magoo's Avatar
Mr. Magoo
From: Damn taxes! Pimpin' Ain't Easy in Massachusetts
2018 C4 of Year Finalist
St. Jude Donor '03-'04-'08-'09
Default SLP Torque Converters?
I'm tight on cash so I could only spend around $300.00. A friend of mine is using this converter and gets great results from it. I originally thought is was a 2600 stall for my Vette but their web site lists it as a 2400 stall.
Anybody else use this converter and what were your results??
Here is the link. http://www.slponline.com/view_produc...RTNUMBER=60100
[Modified by Mr. Magoo, 8:50 AM 11/26/2002]
Old Nov 26, 2002 | 08:50 AM
vettmech's Avatar
vettmech
Default Re: SLP Torque Converters? (Mr. Magoo)
Hey Magoo...... you can ID the stall on the converter by the letters or numbers stamped in it. Look between the ridges around the circumfrence ... they are the same all the way around and they are coded to stall....... I have a listing for some of these and you can see them by dropping the dust sheild :seeya
Old Nov 26, 2002 | 10:34 AM
Mr. Magoo's Avatar
Mr. Magoo
Default Re: SLP Torque Converters? (vettmech)
Thanks bud, I should be recieving it in about a week.......I'll check it out.
Old Nov 26, 2002 | 10:52 AM
Mervz's Avatar
Mervz
Cruise-In V Veteran
Cruise-In VI Veteran
:cheers:
Old Nov 26, 2002 | 11:10 AM
scorp508's Avatar
scorp508
The more power you make, the higher speed it will flash too.
Old Nov 26, 2002 | 12:52 PM
Mr. Magoo's Avatar
Mr. Magoo
Default Re: (scorp508)
Ahhhhhh I like the sounds of that, but is there anyway to control where it flashes too?
Old Nov 26, 2002 | 06:04 PM
SloRvette's Avatar
SloRvette
Cruise-In VII Veteran
Default Re: (Mr. Magoo)
Control the amount of power the motor makes.
You should figure on 100 rpm less than they advertise with the ways things have been working out for you. :jester :smash:
Old Nov 26, 2002 | 09:35 PM
silver & red CE's Avatar
silver & red CE
I've been running the Impala/SLP converter on my Impala for ~30K miles, been very happy with it. Made over 50 passes on my Impala, that's working it :cheers:
Eric
Old Nov 26, 2002 | 11:09 PM
Fastguy's Avatar
Fastguy
St. Jude Donor '03-'05
I am using a Raptor 2,600 and I have been very happy with it. I think I paid $150 for it brand new from ebay. Rick (KamaroSS) with the 87 uses the same one.
Old Nov 26, 2002 | 11:20 PM
Mervz's Avatar
Mervz
Cruise-In V Veteran
Default Re: SLP Torque Converters? (Fastguy)
I'm not a wuss. I shift my own gears. Therefore i know nothing about stall converters. :p:
[Modified by Mervz, 11:20 PM 11/26/2002]
Old Nov 26, 2002 | 11:29 PM
Fastguy's Avatar
Fastguy
Default Re: SLP Torque Converters? (Mervz)
Yeah, I think I saw you in my rearview once doing that.
Keep up the good work.:)
Old Nov 27, 2002 | 01:45 AM
eguyett1985's Avatar
eguyett1985
I've had that converter in my `85 for about 15K and had no problems at all behind my old motor (9.5:1 355/360HP), we'll see in a few weeks when my new 408 is installed though!
Old Nov 27, 2002 | 07:28 PM
ANTI VENOM's Avatar
ANTI VENOM
Default Re: SLP Torque Converters? (eguyett1985)
I am using one behind a modified LT-1 with 3.33 gears. I think it is a great compromise for a street car. I can hit low 1.8x 60 ft times on regular street tires. I don't get to flash the convertor or I will spin, but it was very easy to launch. My first time out in the auto, I beat my manuals best 60 ft time. I drove a Firebird with a modified Lt-1 with a Vigilante 3200 and it was way to high for what I want to do with the car. My girlfriend drives the auto alot and I wanted a nice "streetable" ride. I am perfectely happy with the convertor so far. Good luck
Old Nov 27, 2002 | 08:19 PM
WEH 2000C5's Avatar
WEH 2000C5
Default Re: SLP Torque Converters? (ANTI VENOM)
I just had a 2000rpm stall B&M put in mine along with the shift kit and rebuild. I am not sure what the difference between SLP and B&M but they are most likely very similar considering the B&M is between $280-$300. Even the 2000rpm made a significant difference. :)
Old Nov 27, 2002 | 09:09 PM
Mervz's Avatar
Mervz
Cruise-In V Veteran
:p:
Old Nov 27, 2002 | 11:11 PM
Alex D's Avatar
Alex D
Default Re: SLP Torque Converters? (WEH 2000C5)
What stall would all of you recommend for a relatively stock C4 with performance axle like mine? :confused: I am thinking 2,000 to 2,400 max. Most of the LS1 folks on LS1.com go with a 2,900 to 3,200 Vigilante or Yank. If I would mod a C5 or our T/A, I would probably go with a 2,900 Vig
Old Nov 27, 2002 | 11:34 PM
WEH 2000C5's Avatar
WEH 2000C5
Default Re: SLP Torque Converters? (Alex D)
Alex D:
Since your car has an LT1, I would go for a 2,300-2,500 stall range if it were me. Your LT1 has powerband higher in the rpm range and would benefit more from the extra rpms compared to my L98. Mine probably would have gained a little more from going to that stall range but I am very pleased with it. You COULD go higher but I don't think it is necessary for a street car. Even with the 2,000 I can tell a difference in slowly taking off; its is just a little bit looser than stock...well worth the feel under some throttle.
Old Nov 27, 2002 | 11:46 PM
Alex D's Avatar
Alex D
Thanks for the info WEH !
tell me a little more about how lose the new converter feels compared to the stock converter. I actually would like to stick closer to the 2,000 range since I don't race my cars......I like the looser converter when you do a roll on at higher speeds, like on the interstate....where did you ge the 2,000 stall converter? SLP only sells 2,400 and up......Yank starts at 2,600 rpm.......
Alex D:
To SLP Torque Converters?
