CAST SLAVE Vs STEEL
Old Jun 9, 2020 | 06:56 AM
mudslide's Avatar
mudslide
Default CAST SLAVE Vs STEEL
I’m doing a clutch master cylinder and Slave cylinder and the cast master went in fairly easy but there is no way to fit the cast slave up in there with the line on !! I had it up in there with out the line and the bleed screw hit the body slightly I could cut the tip of to solve that but no way the line will attach to the slave it hits the body before it can get straight enough to thread in! I’m sure since they sell them somebody has a trick to get it installed It also really hits a solinod on the six speed tranny might be that first to forth thing? The car is 1990 base convertible with the cross member supports that also get in the way Thanks for any help
Walter
Old Jun 9, 2020 | 09:28 AM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
I had my originals rebuilt by
http://www.zfdoc.com/index.htm
