1985 Corvette setting the idle
Old Jun 15, 2020 | 06:31 AM
jseremba's Avatar
jseremba
Default 1985 Corvette setting the idle
Hi everybody, I'm trying to set the idle on my 1985 Corvette 4 plus 3. Question do I use the idle screw on the throttle body to set the idle and then adjust the TPS? I have an FSM but a friend has it.
Thank you.
Old Jun 15, 2020 | 07:52 AM
Kevova's Avatar
Kevova
There is a procedure in the the stickies. You need to verify intial timing is correct. You need to be sure throttle bores are clean of carbon build up. Then check minimum air rate or idle 450 +/- 50 reset with screw if necessary. Then TPS. If you have scanner you can verify IAC counts are 20-25.
ECM controls idle speed unless you turn screw far enough that it can't. At that point TPS may not adjust back to .5v
Get your book back.
Old Jun 15, 2020 | 08:00 AM
jseremba's Avatar
jseremba
Thank you for the help. The Idle should be 450? To 500? Am I understanding that correctly? The IAC presently says about 135. There are no error codes. Yet the car has a bad idle. The throttle body is clean. Presently it is running rich. The MAF is adjustable and I have it to the point where it says about 12 g/sec. I will try your suggestion and I will try to get my book.
thanks again
Old Jun 15, 2020 | 08:14 AM
C409's Avatar
C409
..... Adjust the idle stop screw on the throttle body to get about 15counts on the IAC … don't forget to reset the TPS … check IAC counts in gear 20-30 is good … your MAF is too high should be approx. 7gps … my YukonXL2500 with an 8.1 idles @ less than 12gps … do the math to find the correct # for your engine CID and RPM …..
Old Jun 15, 2020 | 08:19 AM
jseremba's Avatar
jseremba
So the idle screw will change the IAC counts? I didn't realize that. I will take a look and try to get the counts down. Right now they are at 135.
Old Jun 15, 2020 | 08:25 AM
C409's Avatar
C409
….. The IAC is an air valve … so are the throttle plates … the IAC adjusts its air bleed to maintain the idle as necessary … what you want to accomplish is having the IAC in a range where it can react to any operating conditions and still do its job … at 135 its near the end of its ability to control idle speed …..
Old Jun 15, 2020 | 08:34 AM
jseremba's Avatar
jseremba
Thanks for the information. I will try to get the idle down to 500 and the IAC counts down. Thanks again
Old Jun 15, 2020 | 01:15 PM
C409's Avatar
C409
….. The actual idle speed is controlled by the ECM … not the throttle plate screw … if the IAC counts hit zero just back the screw out until you see a rough average around 15 counts …..
Old Jun 15, 2020 | 05:46 PM
jseremba's Avatar
jseremba
C409, The car was running rich. My mechanic last night tested disconnecting the Burn Module. I have not heard back on how it worked. The MAF was reading in the 13/14 range. The car has an adjustable MAF so we now have it down to 10/11. And the car is not running as rich. We are going to try and get the MAF lower to the recommended 7/8. The O2 sensor is reading 350/425. And the IAC is steady at 135. Could the IAC be the problem?
If I disconnect the TPS. Can I set an idle with the throttle body adjustment screw. Then plug in the TPS and adjust it to 0.54 volts.
Keep in mind everything the TPS, MAF, MAT, CTS, Fuel injectors, fuel pump regulator, wires, cap, plugs, coil, knock sensor and O2 sensors.
I want to thank you all the help.
Old Jun 15, 2020 | 10:46 PM
C409's Avatar
C409
..... As you open the throttle blades the IAC counts will drop … @135 too much air is being inhaled through the IAC at idle … the ECM controls idle speed by way of ignition timing and IAC to a pre set number in the tune … A tuner can change the idle speed but you can't change it just with the screw … you tune the idle with the screw to obtain the most effective range of operation of the IAC … if you leave it at 135 there is very little it can do to increase idle speed in cold weather or to maintain idle under certain conditions …..
Old Jun 15, 2020 | 11:08 PM
jseremba's Avatar
jseremba
If I disconnect the IAC. Will that help me determine if the IAC is the source of our problem? Thank you
Old Jun 16, 2020 | 07:27 AM
C409's Avatar
C409
..... What exactly is the problem ? …..
Old Jun 16, 2020 | 07:40 AM
jseremba's Avatar
jseremba
The car is idling rough. I have TunrrPro software and it is saying that the MAF is 12/14 g/sec and the IAC is 135 counts. The MAF is adjustable and we are trying to lower the MAF to below 10 g/sec. I asked my mechanic if we should disconnect the MAF. This morning he checked every wire running from TPS, MAF, MAT, O2 sensor all of which are new.
So this afternoon he was willing to disconnect the IAC. He said he needed to remove it to set the plunger. It broke. But, we ran the car and it idled better. The MAF read 12/14 g/sec and the idle was 800 but it did run smoother.
We are going to get a new MAF and see if that's the problem.
I have good fuel pressure 35/40 . And I have good vacuum 20 inches.
We have a bad idle. Obviously new plugs, wires, cap, rotor, coil and module. Any and all ideas are welcome. Thank you
Old Jun 16, 2020 | 11:16 PM
William Morbid's Avatar
William Morbid
Where did you get your adjustable MAF? Do you have a link you can share?
Old Jun 16, 2020 | 11:25 PM
jseremba's Avatar
jseremba
My mechanic had it. I will get the make and model number and send it to you.
Old Jun 16, 2020 | 11:27 PM
jseremba's Avatar
jseremba
The manufacturer is GRANITELLI ADJUSTABLE MAF.
Old Jun 17, 2020 | 07:22 AM
C409's Avatar
C409
….. Carefully re-read posts #2 & #4 …..
Old Jun 17, 2020 | 07:27 AM
jseremba's Avatar
jseremba
Will do. Thank you for the advice.
To 1985 Corvette setting the idle
