U-Joint brand question...
Old Nov 26, 2002 | 03:48 PM
VetBoy89's Avatar
VetBoy89
Default U-Joint brand question...
I was going to put a pair of Spicers' on my driveshaft when I do the trans oil seal and since that's what I have on the half-shafts. But I called NAPA and the guy said they only carry 'Precision' and they are just as good as Spicer. The cost is $8.65 each, that alone scares me, so I thought I would ask the pros:
Has anybody heard of this brand? Are they reliable? Or should I just find a local place that has the spicers?
TIA
Old Nov 26, 2002 | 04:10 PM
scorp508's Avatar
scorp508
Generally you get what you pay for. Call Chris K. at the # below and he can hook you up with the good spicer. :yesnod:
Old Nov 26, 2002 | 04:21 PM
VetBoy89's Avatar
VetBoy89
Default Re: (scorp508)
That's what I was thinking, thanks for the contact info, I'll give him a call.
Old Nov 26, 2002 | 07:41 PM
gtsyellow's Avatar
gtsyellow
Default Re: (VetBoy89)
http://www.gloeco.com/common_u-joints.htm
i have yet to find a cheaper place selling OE spicers, call & buy the coated for aluminum use brute force joints. they don't fail.
Old Nov 26, 2002 | 07:47 PM
scorp508's Avatar
scorp508
Are the 'brute force' ones just what they are calling a certain kind of spicer or is it the actual brand Brute Force? If it is the actual brand Brute Force that come in the black box, those ones are crap.
Old Nov 26, 2002 | 08:09 PM
gtsyellow's Avatar
gtsyellow
nah, they told me they refer to the non greesable cold forged spicers as brute force. i agree the brand brute force sucks !
Old Nov 26, 2002 | 10:08 PM
Juliet's Avatar
Juliet
I just purchased a set of Spicer U-joints (no zerk fittings) for the half shafts from Tony's Corvette for a very good price. :cool: :thumbs: That's all he recommends using and the only brand they install at his shop. Plus they supposedly look exactly like the factory originals. :cheers:
Old Nov 26, 2002 | 10:15 PM
gtsyellow's Avatar
gtsyellow
Default Re: (Juliet)
what did you pay for them? & your correct, they are the only joint worth using in the corvette. napco makes a decent joint as well but it's only a couple dollars less than spicer. i see no reason to take risks.
To U-Joint brand question...
