Adding secondary pusher fan.
Old Jun 19, 2020 | 08:10 AM
84 4+3's Avatar
84 4+3
Default Adding secondary pusher fan.
Simple as the title says. If I were to mount it to the condenser for extra air flow ac on, and wire it into the fan switch on the compressor (84s are different this way it seems) it should work fine no? My only issue is if it'll kick off while at speed. My thought is it should as the airflow over the condenser will lower the pressure enough to open that switch no? My concern is I don't want the fan on all the time and to become a restriction at speed. My main fan is controlled by the ECM now and it kicks out between 30 and 35mph so I'd imagine at those speeds air flow is greater than that of the fan. Thoughts?
Old Jun 19, 2020 | 07:01 PM
wilcar's Avatar
wilcar
You could run a new separate fused circuit through a relay and mount a toggle switch inside and use that as the ground wire for the relay. That way you can use if and when needed.
Old Jun 19, 2020 | 08:46 PM
84 4+3's Avatar
84 4+3
I'm just looking to use it as a little extra help for the ac more than anything. Thats actually how I run the second fan in the 67.
Old Jun 20, 2020 | 09:41 AM
84 4+3's Avatar
84 4+3
Originally Posted by ihatebarkingdogs
Then wire the second fan to the Lt Green wire on the high pressure cut out switch. The lt green wire is hot when the mode switch (or the C68 Controller) is calling for AC. Ie, MAX, NORM, BI-LEVEL, or DEFROST. I don't wire to the dk green compressor clutch wire because as the clutch cycles, so will the fan. Hard on the fan motor, alternator, and especially the relay. The constantly cycling fan will become annoying for its noise, and the idle constantly being affected by the alternator load. The condenser benefits from the increased airflow even when the compressor is cycled off. Fan = ON anytime AC is selected, but clutch is not necessarily engaged, is the way Vintage Air does it. Much easier on electrical components, and better AC performance.
If I were doing this addition, and wanted it mostly for increased AC condenser performance, this is how I'd do it. I would also add the stand-alone control switch in the head for the aux fan, the way the OEM B4P fan is wired. This would add stand-alone redundancy in case of main fan failure for whatever reason. Again, the way the B4P functions. B4P is completely segregated from anything to do with the Main Fan, other than the shared blue wires to the relay coils from CFAN fuse which is hot in RUN.
If you do the AC and switch controls, you'll need two relays for the aux fan. The lt grn wire is B+, so the other side of the first relay coil is direct to ground. The head switch switches to ground, so the other side of the second relay coil goes to the dk blue wire (hot in RUN) for the Main Fan. The battery source and fan motor outputs of the two relays can be paralleled.
But thats again the problem, the 84 setup is oddball. The ecm never controlled the fans factory, the switch in the head on the 85 and up cars for the aux fan is the main fan switch for 84. The ac fan call was done by a pressure switch mounted in the top of the compressor that only ran during high side pressures above a threshold. Right now I'm using the later ecm to control main fans but if I were to wire the aux fan like the optional one, I lose the redundancy on the primary fan incase the wiring I added goes awry...
The system cycling switch on the back of the compressor hose seems like a reasonable approach though. But again, if it is running all the time because that's hot comp on i would imagine at speed that fan becomes a restriction no?
Old Jun 20, 2020 | 02:28 PM
C6_Racer_X's Avatar
C6_Racer_X
If the AC system is operating properly and properly charged, the high side pressure switch should do what you want.
You can either run that as an alternate ground path for one of the fan relays (dark green or dark blue wire) or you can add a pusher fan to the front of the condenser.
I often add a pusher fan to S-series pickups and SUVs using that switch and a relay. Sometimes I'll also add the lower temp switch in the head (the 215F on, 200F off one for the third generation Camaro that doesn't list C4 Corvettes in the applications), although on the trucks, if the fan clutch is good, that switch isn't needed.
Old Jun 20, 2020 | 08:48 PM
Hot Rod Roy's Avatar
Hot Rod Roy
Why do you think the running fan will be more of a restriction that a non-powered fan? As air speed goes up, electrical current to the fan will decrease. A non-powered fan will spin in the breeze, which is obviously a restriction to air flow. How much restriction are you concerned with? Will this affect your quarter-mile times, or how are you measuring this "restriction at speed"? At very high speed, the fan motor will become a generator, which will reduce the load on your alternator!
Old Jun 20, 2020 | 10:14 PM
84 4+3's Avatar
84 4+3
I've had some other vehicles woth fans wired on all the time and they cooled better fans off at 55 vs fans on. Idk why but it did. Doesnt make sense i agree.
To Adding secondary pusher fan.
