Offset for 18x10.5” wheel 1985
https://esrwheels.com/collections/rf...31792676929654
So taking into account the change in offset (16mm) and the wider wheel (12.5mm each side), the wheel will be 28mm closer to he fender assuming 9.5” original wheels all round.
Personally I think they will stick out too far but the best way is for you to drop a string line down and measure. They might fit on the rear but I don’t think they will on the front
OP - What is the 'up-charge' for 'custom' bolt-circle? Merely an observation but they seem to offer a 9.5 @35 with bolt-circle options!
I honestly don't quite understand the desire for extreme tire section width/foot print for a road car!
Greg @50 won't work for his rears!
@GregMartin - when you've the opportunity since you've a wheel I'd suggest you just try your 11' @ 50.
To the OP's original question, a 10.5"/315 with 22mm offset is probably going to poke out. I think you'll find that 32mm is what you want with this wheel size, too. All of what I wrote above still applies.
RE your laws, it's going to depend on how they measure "stick out past the guards." Also, you wrote "wheels," which would give some wiggle room to work with; but if the law is that sidewalls can't be outside the fenders then 11/315 is going to be really hard to make work. IME, with properly fitted 11/315s, the edge of the tread is about even with the top of the fender edge, but the middle of the sidewall where it bulges out on most tires will protrude past the fender edge. If you can't run 50mm offset due to inside interference, then the Grand Sport flares would be one obvious solution: GM tacked them on specifically to make the Grand Sport street legal in the US for the same reason.
PS - I know you can figure this stuff out on your own! I'm just trying to give you a head start on what to check for when you try those wheels and tires.
