So I've searched around and I can't seem to find an exact answer. I'm sure somebody knows where the sticky is. Looking at purchasing ZR1 wheels for my 95 C4. I want the 9.5 up front and the 11 on the rear. What is the correct offser/ backspacing for the rears to not stick out. Thanks in advance for the help.
To put on a 95, you want the 50mm offset that was on the grand sports in 96. They will still stick out a bit but not much (the reason they put the flares on the grand sports).
The Zr1s had 36mm offset which is what gave them the extra 3" of width.
How about my 87, Can I get the 9.5 56mm off set front and 11 50 mm off set rear. Both with spacers. 1/2 inch rear spacers. Will they stick out too far?
Unless you go to an 18X10.5 or 18X11 in the rear. Then there are a ton of choices in 315 or 335 series tires.
I'm not so sure about that. In 315/30/18 Tire Rack has only two tires that aren't intended for competition use, and they cost $333 and $477 each. There's only one in 335/30/18 size and costs $470, and the minimum rim width spec for it is 11.5". That said, there are tons of choices in 275/35/18, or 285/35, or 295/35. Any of those fit properly on a 10.5" or 11" wheel, and are good diameters for a C4.
They may not stick out quite far enough. To be more precise, they may have too much backspacing and rub on the inside. You'll need to experiment with different spacer thicknesses, but it's more likely that you need 3/4". That will give you the exact same wheel location up front as your 87 had when equipped with 16x9.5" wheels from the factory (38mm offset). With 11s, things are tight and so in back you'll have to see how things fit with 1/2", 5/8", and 3/4" spacers.
