Anybody ever run into this?
The stat was in fact, restricting flow, causing hot...NOT cooler, running.
Why high flow water pumps? Why high flow cooling fans? Why high flow thermostats? I'm not busting your *****. I wasn't busting Patrick's *****. He learned a thing that day. Frankly, we both did. I just got lucky and the likely hood of a partially stuck open stat crossed my mind while Patrick and I were talking. He confirmed it.
IDK why you saw the results that you say you saw. You car isn't mine, I'm not there to see what it's really doing, myself. I can't run a test or a few to try to fully understand the root cause of what would create those results. I've ran cars w/o any stat at all...they sure didn't run hotter! They'd typically run in the 140* area.
I can run a test on one of my vehicles if anyone is interested. This topic is debated often, and will be, forever. If anyone calls for it, I'll go pull the stat from my truck and run it...document the results. Let me know.
I remember one time I pulled my boat out of Lake Powell in July, this was with my truck (silverado) not the 'Vette, but...air temp was 115. Leaving lake Powell is a climb. I remember having the AC blasting in the truck and opening the window....it felt like opening the door to an oven. I remember thinking, "I don't know how TF the truck can possibly keep itself cool enough in these conditions!": 115 air, AC on, towing my boat, climbing mountains @WOT/lower speeds (air flow). But it did it and did it w/o even nudging the temp gauge above it's normal range -about 200*. These systems should be and are designed to be overkill. The 'Vette should be able to do about the same (w/o towing a boat, probably).
Anyway, in your 'Vette with the electric fan, the temp should rise to ~"max on the gauge"(which is totally inaccurate) and show ~230* on the digital display, and the fan should turn on. With the fan on, temps should be driven down to ~217* w/in minutes. I'd say w/in about 2 minutes unless oil temp is way up from track use etc. The fan shuts off around 217 (~mid-point on the worthless gauge) and with out movement/air flow, the temp should climb back up to ~230* again. And on and on.
If your fans don't drive the temps down pretty quickly, somewhere your cooling systems capacity has been compromised; blockage of air flow, sludgy coolant, poor flow, whatever, and should be looked at.
Exactly
There should also be only one location that's open to the atmosphere, and that is at the reservoir. If your radiator cap is open to the atmosphere, you'll have no coolant recovery from the reservoir to the cooling system as the engine cools! If you have an opening at the radiator cap, coolant will eventually overflow the reservoir, and the radiator will run low, causing a host of problems. Your radiator should stay 100% full at all times. This also reduces air from getting into the cooling system, which reduces corrosion. I think you knew that too.
Boiler theory is interesting, but irrelevant, unless you're driving a Stanley Steamer!
and has a seal... in regards to the post above if there is steam coming out of anywhere else it is a big issue. If it is coming out around the cap, seal is damaged, pressure is being lost, there is a place for steam that shouldn't be created to escape and a pretty obvious problem. Won't do it at 185*F though. Replace the cap and problem goes away. There is no designed opening in the rest of the system that is serviceable. Teh rest were designed to be sealed and stay sealed. Last edited by KyleF; Jun 25, 2020 at 03:34 PM.
