Help with my data log?
Old Jun 27, 2020 | 03:21 PM
AgentEran's Avatar
AgentEran
Default Help with my data log?
So yesterday I went to the dyno to get a read on my wheel power and get a tune. Good news is that the tuner was able to get my idle and mid range driveability WAY better, but was not able to tune the WOT.
We were seeing what appears to be a misfire in one cylinder on the divers side. You can hear a slight miss once the rpms started to climb above 3500 rpms so he basically side, "hey go figure out your misfire and comeback to get a real dyno tune/readout of your power at the wheel". As for the power it did make, it was making 350tq at the wheel at 3500 when the misfire condition would develop. The tuner felt pretty confident this was being caused by fouled plug or bad wire. He was confident the misfire was spark induced. Looking at the data logs since leaving the dyno I do see that at various rpms the bank 1 o2 sensor is reading much higher than the bank 2.
What in your opinion is causing this? Do you agree its spark?
I should add that this chart is sorted by time, then filtered for instances where there was an amount of difference in the o2 readings. This is that the totally unfiltered chronological log data looks:
Old Jun 27, 2020 | 04:12 PM
FrankieD's Avatar
FrankieD
Can you provide a datalog at higher RPM when the problem is happening
Old Jun 27, 2020 | 04:52 PM
ChumpVette's Avatar
ChumpVette
Since Golen ran it on the dyno, I would say we can rule out a mechanical issue with the valvetrain.
I would like to see the full scan log to give a better opinion. Seeing info in bits and pieces doesn't really help. Since you have headers, go ahead and remove the plugs and inspect them and see how they look. Throw up some pictures as well. If you are really ambitious, you can pull the plug wires and inspect them for possible breaks and ohm test them as well.
I am surprised that the car did not trigger a misfire code, for either a specific cylinder or at least the general misfire code.
Old Jun 27, 2020 | 06:01 PM
AgentEran's Avatar
AgentEran
Agreed.
Let me know what sensors to add to this data log I can select what I want.
Im going to pull the plugs and see what they look like as well. Ill post pics later.
I dont think I can have a misfire code because the crank position sensor has been removed and programmed out.
Old Jun 27, 2020 | 06:44 PM
FrankieD's Avatar
FrankieD
If you can attach either an Excel or csv file attach all data/sensors
Old Jun 27, 2020 | 08:49 PM
Kevova's Avatar
Kevova
Oscilloscope would be helpful. I'm somewhat surprised dyno shop didn't have one.
I wouldn't have thought to bring a 2nd set of plugs and wires as a just in case. Now I know spare parts maybe required.
Old Jun 28, 2020 | 12:02 AM
AgentEran's Avatar
AgentEran
Im sure he did but he had other customers to move on to. I plan to call him up on monday and see about coming back. He was pretty adamant that he was not doing repairs, just dyno lol.
Old Jun 28, 2020 | 12:12 AM
AgentEran's Avatar
AgentEran
I am data logging with Torque app so I dont have access to all the data the ECU has. What data elements were available I added to the log. In this log the car drove fine until about 5:43pm. I then pulled over and sat until 5:57pm. This is when the condition is experienced and it lasted for at least 3 or 4 min, then the car went back to driving decent again.
Old Jun 28, 2020 | 03:21 PM
FrankieD's Avatar
FrankieD
From the limited data that Torque App provided I can see that the " O2 Volts Bank 2 sensor 1" is reading 0.35 volts and under for over 40% of the entire datalog that you provided. To me that represent significant Lean event on that side. I would concentrate your efforts on that side of the engine (whatever side O2 Volts Bank 2 sensor 1 represents)
Old Jun 30, 2020 | 09:31 PM
AgentEran's Avatar
AgentEran
Frankie D gets the cigar.
Your comment helped me find the issue. Lean as we all know is generally caused by vacuum leak or more specifically unmetered air! This got me looking around and I found that the stock intake tube was a bit too small for the 58mm TB that's on the motor. This caused a tear on the underside of the tube just under the throttle body. This of course is after the MAF and would be unmetered air. The condition is exacerbated when rpms increase along with the amount of air leaking through the hole.
So I went to Lowe's and picked up a 4 x 3 inch rubber plumbing coupler and slapped it on there. Now both O2 sensors are within normal range and the car now runs like a scalded dog. Headed back to the Dyno next week.
It's running better than I ever anticipated. I was driving down the street in 3rd at about 3500 rpm and decided to rip it, well the car went into a full burnout.. at 65mph. Not wheel spin, burnout. There was so much smoke I thought I broke it. There was so much smoke that there was smoke coming out the gear shifter boot.
Old Jul 1, 2020 | 12:20 AM
FrankieD's Avatar
FrankieD
With unmetered air I would suspect the entire previous tune will need some correction as well.( Make sure you ask your tuner to go over it) Looking forward to your final results.
Old Jul 1, 2020 | 12:29 AM
Theman5's Avatar
Theman5
Old Jul 1, 2020 | 12:43 PM
AgentEran's Avatar
AgentEran
Here are some pics
The tears/hole in my intake bellow:
My fix:
To Help with my data log?
