TPMS Questions
Old Jun 29, 2020 | 12:39 AM
corvette72778's Avatar
corvette72778
Default TPMS Questions
Had a few TPMS questions for my 96:
1. How do you diagnose the "Service TPMS" light on a 96 Vette?
2. I'm going be putting 17" ZR1 wheels on. Can I transfer the sensors from the 17" sawblade wheels to the new 17" ZR1 wheels?
3. What precautions does the tire/wheel installer need to take in order to not break the sensors? How do these get broken? Only 1 sawblade as the sticker on it indicating the (assumed ) sensor location.
Old Jun 29, 2020 | 01:12 AM
Theman5's Avatar
Theman5
1. OBDll reader ? Check owners manual ?
2. How old sensor? Batteries don’t last but 5-10 years on average (less it seems nowadays with junk being manufactured overseas)
3.sensor should be at valve stem in most if not all cases. Sensor can get broken by machine misplaced when mounting or unmounting tire. Usually batteries fail
Old Jun 29, 2020 | 01:20 AM
corvette72778
Every answer you gave was completely useless. C4s use a wheel band sensor not a valve stem sensor.
Old Jun 29, 2020 | 01:29 AM
Theman5's Avatar
Theman5
well then you know more than you let on. No OBDll or owners manual? Maybe this of more use to you or not.
C4: The C4 system uses a transmitting wheel sensor held in place by large band clamp. Each sensor has a separate identification color and frequency, which is transmitted as the wheel turns. If a sensor gets mounted to the wrong wheel, a Diagnostic Trouble Code (DTC) will be sent. Wheel position, sensor colors and Diagnostic Trouble Codes (DTC) are as follows:
  • Right Rear: Orange, DTC=24
  • Left Rear: Yellow, DTC=34
  • Left Front: Green, DTC=44
  • Right Front: Blue, DTC= 54
It is possible to attain the code from your dashboard. With the key in the “on” position, press and hold the “Trip/Odo” button until “1.1” is visible on the trip odometer readout. Next, press the “Eng/Met” button to scroll down the present code list (which is displayed at the MPH indicator) until you see the applicable one.
The movement of the wheel provides the energy necessary to power the transmitter. If the tire pressure drops below 25 PSI, the sensor stops transmitting to the receiver, and the “Service LTPWS” lamp illuminates. The sensors don’t require batteries, and the receivers don’t need to be reprogrammed. (source: VetteWeb, Corvette Fever)
Old Jun 29, 2020 | 01:40 AM
Fiberbundle's Avatar
Fiberbundle
There is a very little bit of adjustment on the band that MAY allow you to transfer the sensors to your new wheels so you should be OK on that issue since you are using a stock wheel.
The sensors are mounted directly opposite the valve stem hence the label being at 90 degrees from the stem from the factory. The installer needs to be very careful, especially when breaking the bead to get the tire off. The plastic housing is brittle but not overly so, however that is what is usually broken. Stand next to them as they work on the wheels. If they will not let you do that either get a written guarantee that they will pay for a new one regardless of cost or find a different installer.
Light will be illuminated every time you start the car and remain on until you drive a quarter of a mile or so. They are self generating for power. If the light does not go out after that time there is a problem with one or more of the sensors. Sensors have often been removed by owners due to damage. If the light remains on there will be a code set telling you which sensor has an issue.
Ask if you need more information.
Old Jun 29, 2020 | 03:40 PM
corvette72778
Thanks for the info. That should help when we take the tire off.
How can I check to determine which sensor may be bad? I don't mind buying a used one on Ebay to try to fix it.
Old Jun 29, 2020 | 03:51 PM
Fiberbundle
I am not sure if you know how to check the codes in your car but it is well documented in posts on this forum.
Once you know the codes that are set, the following tells you what is going on with each sensor.
Each sensor is colored differently and will set a different code with Orange (RR) setting 23 or 24, Yellow (LR) setting 33 or 34, Green (LF) setting 43 or 44, and the Blue sensor (RF) setting 53 or 54. This was done so techs could tell which sensor was malfunctioning if actual tire pressure was not an issue.
However this is only true if the wheels and sensors were put back in their original location after and service work was completed. If out of their original position you will know the sensor with an issue but not which tire it is under.
Old Jun 29, 2020 | 05:09 PM
KyleF's Avatar
KyleF
1. Start by checking the PSI in your tires. Seems crazy, but with small sidewalls maybe you don't notice it is down on pressure? The rest, I would be pulling out my FSM as I have never had that issue before.
2. When I got my car it had C5 chrome 5 spokes on it, with funtioning TPS. They went right back on the A-Molds I have. Should be no issue with the same diameter
3. This type of system was not all that rare some time ago. You just need a shop that knows what they are doing and will take their time and do it correctly. Make sure they know what is in there if their system doesn't already. I swapped wheels with zero issues.
To TPMS Questions
