1985 CORVETTE iat sensor
Old Jun 29, 2020 | 06:07 PM
Ian.g's Avatar
Ian.g
Default 1985 CORVETTE iat sensor
so i have an 85 corvette, and i just swapped the heads on it. while i was plugging everything back in i noticed a sensor under the intake manifold, but no connector in sight. i spent hours looking for it, until i gave up and bought a new wire harness. the new harness has no connector for it either. Am i making a mistake and that sensor was never connected in the first place? maybe the manifold is from a newer corvette?
Old Jun 29, 2020 | 06:28 PM
s carter's Avatar
s carter
Photo of sensor please,
Are looking plug for sensor that is on right side by pipes
Old Jun 29, 2020 | 06:44 PM
Ian.g's Avatar
Ian.g
thats the sensor, on the right side of the photo, the screw in one
Old Jun 29, 2020 | 06:51 PM
s carter's Avatar
s carter
There should be a wire for it it's one of those kind of important plugs. Did I you take the car apart because I always unplugged it and rerouted it from under fuel rail when working but with that said I can't swear if there is removable pigtail extension that goes to main harness that might be missing
Old Jun 29, 2020 | 06:57 PM
Ian.g's Avatar
Ian.g
removable pigtail?
Old Jun 29, 2020 | 07:23 PM
s carter's Avatar
s carter
Originally Posted by Ian.g
removable pigtail?
https://www.ebay.com/itm/85-92-TPI-I...edirect=mobile
Old Jun 29, 2020 | 07:37 PM
Ian.g's Avatar
Ian.g
well that explains that
Old Jun 30, 2020 | 12:04 AM
jazfe's Avatar
jazfe
Must be an 85 thing. My 86 IAT connector is hard wired in the bundle.
Old Jun 30, 2020 | 07:49 AM
s carter's Avatar
s carter
I have to Agree with you about it being Hard Wired into the Harness I never recall Unplugging the Sensor any other than at the Sensor. but when searching for the Photo of the Plenum the Pigtail showed up several times.
Old Jul 1, 2020 | 12:01 AM
TommyFox's Avatar
TommyFox
Is it possible someone installed a IAT relocation kit? Name:  ebmiDwQ.jpg
To 1985 CORVETTE iat sensor
