VALVE COVER GASKET
Old Nov 27, 2002 | 12:04 PM
RUSS105's Avatar
RUSS105
Default VALVE COVER GASKET
How much should it cost to have a replacement done due to a leak?
Old Nov 27, 2002 | 12:18 PM
ELEVENS's Avatar
ELEVENS
Default Re: VALVE COVER GASKET (RUSS105)
what year car and what side? The side w/o the AC is pretty easy. The other side, however....
Old Nov 27, 2002 | 12:41 PM
RUSS105's Avatar
RUSS105
Default Re: VALVE COVER GASKET (ELEVENS)
I have a 85 L98. I think I may need both sides. Could you please break it down bi side as well as a 2 side job?
Old Nov 27, 2002 | 02:05 PM
VetBoy89's Avatar
VetBoy89
I know the 85 is a bit different from my 89 but book time for mine is:
$13 per gasket
Right Bank: 4.0 hours
Left Bank: .8 hours
Both Banks: 4.7 hours
That should give you an idea, someone with more '85 knowledge should chime in.
Why not do this yourself and save $400? :smash: :D
Old Nov 27, 2002 | 02:11 PM
fullboogie
Default Re: VALVE COVER GASKET (VetBoy89)
And you'll learn something about your car in the process.
65Z01's Avatar
65Z01
Cruise-In II Veteran
Your '85 is easier than the '88 and later L98s but you still need to remove the EGR tube and maybe move some accessories forward to clear the covers.
Maybe 2-3hrs of labor plus the gaskets; make sure your mechanic uses the FelPro PermaSeal gaskets.
Give your local Chevy dealer a call; the quote and their rate will tell you how long it takes.
To VALVE COVER GASKET
